Hey all,
I just got my R/T mount in the mail from Roostmonkey and it looks great! Since im going to be installing this i figured i might as well get some fuel things in order. so.....
My fuel pump went out not to long ago and i was short on money at the time. So i ended up getting a cheap $41.00 universal fuel pump from Pepboys and im currently hating it. Its loud, draws a crap load of amps and only flows 2.5-3.5psi. I have been told that the ideal fuel pressure for my carb setup (duel stock webers) is 4-5 psi., so im running short there. Also, i currently do not have a regulator on my fuel line. This is the fuel pump/regulator combo that im looking into. The combo is only $97.00 for both...
the fuel pump:
105 gph (free flow)
70 gph at 9 psi
High pressure 14psi max
and the regulator:
4-1/2 to 9 PSI
3/8” NPT Ports
restriction: .220” (7/32”)
-Would this be a good combo for my 260? if i set the pressure regulator at 4.5 psi?
-The install directions say to just block off one of the 'out' ports if running a single carb setup or run it to a gauge. i will probably run it to a gauge either an in-line or electric, not sure yet. It all depends on the cash flow.
they also sell a low psi pump if that would be a better choice
95 gph (free flow)
65 gph at 5 psi
Low pressure 7 PSI MAX
Thanks in advance.
