Posts posted by Drift Boss
Setting in the bay, bolted up.
Trans fitment. I have to get soarer shifter
Now, i added 1/8 steel angle iron to the frame rails,and YES there is a rubber mount between the frame and mount.
Also, the holes are drilled threw the rear subframe, so you know it has a very strong bolting area.
Next up...mounts!
I went and bought a 220volt welder. Lincoln seems to be the great brand. I have owned 3 lincoln units before, none gave me any trouble.
These are the EASIEST mounts i have ever made. I have done countless rb mounts/1j/2jz 240sx setups....
All you need is the 1/4 x 4 inch flat steel, and one peice of 1/8 x 1 inch flat steel.
Cut the mount plate on side of engine, drill 4x holes. Then cut 9.75 inch long of flat steel. Then cut braces for the sides, make sure you set them in and tack weld before you fully weld them.
Pretty much a 90 degree design. Keep in mind k am.not a professional welder lol..
No gas weld!
Fitment issuess (for me)
Ac has to go...
Most mount kits run their trans mounts of this...i had to cut it out...it hits my trans.
Refinished the intake manifold
Removed these...
Line install
Plug
Well damn! That's better parts then what i started with! My pan is also from a sc300.
And... Throttle body gasket
So since they dont sell 1jzgte middle intake gaskets...i made my own.
I just made my own mounts. Very easy to do. I used 1/4 steel. 4x1/4, i believe you can get a 20 foot long peice from any steel supplier for about $70
I will go over my mounts in detail soon!
Dallas jdm or something like that. they are in Dallas texas.
I do have a rear sump oil pan, i am welling to sell.
Oil line kit drift motion
Egay wastegate
Clutch!
Flywheel with arp bolts
Drift motion manifold
Garrett ball bearing turbo
Downpipe kit (DM)
Engine
Rebuilt trans
gettete r154
Mines already in, just have to catch this build up to date
Yeah, i do. Its a 1jzgte, i converted to single.
The 302 made 280WHP.
Mods
Trick flow allu. heads
202 valves
Custom cam
Custom push rods
T5 bw trans
Ac!
No power steering
Roller rockers
Hydrolic lifters
Elbroke intake and carb
Forged flat top pistons
Prettt much every bolt on known to man. Only made 280...
Next thing, replacing the mirrors...
Much better...
Hey guys, long time no see, but i do troll on here as everyone does.
Here is my Datsun 280z!
I bought it for the shell mainly. I loved driving around the Ford 302...but it wasn't the engine platform i preferred.
So..
BUILD
First thing i did was remove the good awful huge 280 bumpers, and rear louvers.
Looking for the fallowing parts
Rb20/25/26 conversion motor mounts for (76) 280z chassis with rb25 trans
Rear sump rb20/25/26 oil pan with pick up tube!
V8 to 1jzgte Build
in S30 Series - 240z, 260z, 280z
Posted
Now i am cought up. Next i am going to try to do the trans mount. Wish me luck!
