SDgoods
    4
Everything posted by SDgoods
  1. I believe thr different hole patterns are for datsun roadsters
  2. JPNGarage, Are these wheels made in malaysia? Who makes them? Are they gravity cast?
  3. Bumping this, there is so much misinformation going around, this should be stickied, I am trying to figure out what gasket to use with my p90/F54. The gasket that came off and the Ishino/stone gasket I bought (p79 I believe) block off most of the ports on the spark plug side of the engine, being the "oem" gasket. Other than the 2 sentences stated in this thread: I have not come across anything regarding those being blocked off. Is this side of the engine the feed or drain portion?, as mentioned by TonyD, which really matters where the restriction is. Understanding that the OEM is meant to block these ports off, the question is, will the older gasket benefit the head with opening up the spark plug side ports and will it seal with there being too many holes in the gasket? (as verified by looking at pictures of the gaskets in relation to my head.)
  4. l28ET in 73 240z I found very little information regarding this valve. It's the valve that connects the cyl head outlet (that goes to the heater core) to the Heater core outlet (that goes to the water pump), and it allows water to circulate upon the engine warming up as opposed to just sitting in the engine itself and potentially creating hot spots. Now, This requires a fitting off the back of the head with 2 ports; one port going to the heater core, the other going to the Y pipe that connects into the heater core outlet (and back to the pump) The one that came with my car has one port, and when i got the car, the system was simply hooked up with lines going to the heater core and from the heater core. So, is this setup with out the radiator bypass valve safe to run? (lines going straight to and from the heater core) If not, is there a source for this radiator bypass valve (I cant seem to find one). I'm really trying to get my stockish and relatively simple setup running as efficient as possible by doing things 'the right way', rather than simply modifying and hoping that it will work. Any input would be great!
  5. I believe this is Nissan Pacific blue
  6. The bar isnt going anywhere. What is your concern with the harnesses? When the bar comes out again im getting a rod welded in right there to keep them sliding laterally.
  7. As he said^^ , Bride exas III. I got it used off a miata forum for $600, new theyre around $1000
  8. Why not get the best of both worlds and buy or build a quality roll bar? This is my Custom 100% bolt in bar. It does require 8 holes to be drilled through the rear fender wells, but it can come out at any time.
  9. I managed to get a free set of .015 shims from silverseal because of how long it took them to ship my other ones! With .015, I'll be .005 raised from stock, which I think (hope) is marginal enough to be acceptable, compared to .010 below stock with out shimming. Thoughts?
  10. If you can find a shop or a friend with a smoke machine, they work great
  11. Ill be able to afford to do it right along with the battery tray rust etc.. When i graduate in a couple years. I dont have room in my garage or a cherry picker, and the block and rotating assembly work fine for my current goals. Why tear it apart?
  12. Could have, but didnt, dont have the space, tools, or budget. Workin with what I got, and i didnt ask for speculation on what i could have done. Thanks for your help though
  13. Measured today on a granite surface with a height gauge, came in at 4.2380, so .010 variance from "stock". Should I even shim for .010??
  14. You missed the point, the block is in the car , hence my problem
  15. It would be a tricky and unique setup to that car, but it could probably be done, and would certainly look badass.
  16. Located in San Diego Looking to buy the wide heat shield for the n42 intake manifold. I'd prefer to pick it up but would pay shipping for the right price! Let me see what ya got!
  17. The shop measured 4.2345" with whatever they used.
  18. excited to see the new build start. I knew from the day you sold the others that you'd eventually have another. This should be the best one yet. You know my input, stay with it and keep it simple
  19. Well, I managed to find the user manual online. Old/hardened/porous source lines can cause problems. it also looks like 2 of the ports are supposed to have "vacuum filters". I'll get some new hose on there and try to source a "vacuum filter"
  20. I agree, my mic is not cutting it, I'm going to use a friends navy spec/calibrated tool. Ill post results when i get them
  21. What??? They cut the top. They removed the remaining studs (?) on the head that were able to stay on ffor the bottom to be surfaced
  22. It must be my outside mic, it is probably not ideal for measuring the head. it's difficult to get a perfect, flat reading the same everytime. They are an experienced shop, and I do trust that they machined it flat, however, i'm very confused as to how shaving ".022" from a head thats originally 4.248" ends up at anything more than 4.226". If it were less, it would mean the head was previous shaved, or they shaved more than they thought they did. In this case, either both of our tools are inaccurate or they didn't shave as much as they said.
  23. I just got my p90 back from the machine shop, who apparently took off .012 off the bottom and .010 off the top for a total of .022. I bought .030 shims as I figured after .012 was taken off the bottom, about the same was off the top. Now, in measuring the head height, im getting as low as 4.235" and as high as 4.240". According to a couple sources on this site, stock head height is 4.248. I'm using a matco outside mic that was calibrated in 2011, and measured my .030 shims at .034 (not sure if the mic is slightly off or the shims). 4.248- 4.235 = .013" (????) I was careless and didn't measure it before it went to the machine shop SO, in order to shim the cam correctly, do I go off what the machine shop told me, and stretch the chain .008" with the .030 shim, or closer to what my head thickness is telling me and shim a lot less? The numbers don't add up to the actual thickness of the head according to my mic. The machine shop measured is at 4.2345" (so it is accurate to my lowest reading) Any speculation would be great, as i'm lost at what to do!
