Grandpa 1
Content Count
14 -
Donations
0.00 USD -
Feedback
0%
Community Reputation
0 NeutralAbout Grandpa 1
Rank
Newbie
Location
Odessa Florida
Recent Profile Visitors
Grandpa 1 started following Hard wire wiper motor
Need some help trying to wire up a Honda Accord wiper motor without using the column switch. I see a lot about how to wire using the stock wiring but not much on making it work with an separate switch. It’s for my 75 280z. Most of the links I click on cannot be opened or are expired. I’d like to use a 3 way aftermarket switch. Any help will be appreciated. Thanks
I’m looking for alternate gas tanks for my 75 280z that will use the stock filler. I see some Jeep tanks and camaro gas tanks. Anyone have pictures of their set up? thanks
Looks like that wire is just to show the alternator is charging. I could the solder in a resistor and connect that to a new dash light. Thanks
Need a little help with the signal wire. I see you need to add a resistor but where does it go from there? The harness is from speedway motors. I have the main wire to the starter along with the positive battery cable. Sorry if this has been asked before but I can’t find it. thanks
Has anyone tried the hooker cast iron headers? Are there any options other than the Sanderson? I'm using dirty dingo mounts and 700r4 tranny. Thanks
I used a camaro oil pan from Rock auto and pickup tube , wind age tray. Nice low profile. Much cheaper.
Which oil pressure sensor should I use? It's for 4.8 and I'll be running a carb. Will a stock one work to also act as a fuel pump cutoff? I know for a gen 1 small block you use the Chrysler set up.
I have a 240z tank and do not see any ports for fuel in or out. I see all of the vent lines but nothing else. Any idea of what I have and how to make it work?
Ok so now I'm even more confused on which oil pan to use. Putting a 4.8 l and will be going with a 700 r4 tranny. It's going in my 75 280z. Probably JCI mounts unless anyone can suggest a better set up. Looks like there are several oil pan options? F body , GTO, corvette. What's everyone running?
Thanks for all the responses. I have one now
Thank you
Don't know what happened to the first post.. Anyway need some help finding 27 spline stub axle. Buggered up the threads when changing the bearings. Anybody have a source at a reasonable price? Thanks
Looking for help with dash. Just have the metal frame. Can the full dash cap be placed directly to the metal or do you have to cover over an existing dash?
Thanks haven't heard of that one before
Thanks for the heads up. It was a generous offer,great forum
