I have a set but there are two kinds. The kind that mount to the glass and the kind that mount to the hatch with hings and lock pins. Mine is the hinge type let me know if you are still in the market
How does the the internal regulator work. I got 12 v on the batt lug and 12v on the red and white wire in the connector what is the green wire in the connector? Any info would be great thank you. Jason
The alt will not charge but it is good the car is a 77 and is internally regulated. Can some one tell me which alt wire is suposed to do what. my haynes manual only give the wiring dirgram for the externally regulated alt. Thanks Jason
The carbs are dumping fuel out the front after the engine is shut off. What would cause this? I tried another pair but the motor will only start with a shot of starting fluid. This is really frustrating. The first set are three screw and the second ones are four screw. both were said to run when removed. Can anybody help.
If anybody gets a chance you need to go to the reno air races. Usally in september. The only place you will see p-51s and like aircraft 100 feet off the ground flat out around pylons. You also can get up close with a pit pass. Lots of old planes and some good stunt flying.
I got the transmission apart and the shift fork for fith and reverse is bad. Every thing else looks good just need to find a new fork. Still can't beat it for 200 and very little rust only whole in the truck is in the bed where it got wrecked.
