riverz
Everything posted by riverz
  1. Why are you guys saying that you need to cut out parts of the car to get duel exhaust. Mine has duel exhaust with a h pipe and two mufflers. Don't have anything cut up. My mufflers are mounted vertical, so it takes up less space. My car is a 77 280z with a 700r4 and a 350.
  2. ford put that motor in svo mustangs from the factory. It would be easier to just buy one. So my vote is for a 240 thru 280.
  3. I found 4 1:25 scale models at walmart in south carliona. If anybody wants one I need to know by sunday. The models are made by revell I think. Don't have the box in front of me.
  4. I have the jtr latch on mine with a hei. Have to remove the latch to take the cap off with the accel coil. I am moving mine to the side like pete did
  5. They make a electric hatch realese for our cars. Saw it in a v.b. cataloge. (I think) Thats the way im going to get rid of mine. jason
  6. update the alt light also comes on when you put it in reverse. Please need help car needs to work on tuesday morning any ideas???
  7. I have a 78 280 2+2 I got a new alt. The old one over charged and blew the fuseable link the new problem is that when you use the blinker the alt red light and the fasten seat belt light come on but the blinker don't work. Also the alt light stayes on until the fasten seat belt light goes out when you first start the car. I know somthing is melted but can anyone give me a place to start looking.
  8. I would like to get a copy if it is possable. thanx jason
  9. reminds me of the guy who put jato rockets on his car.
  10. I bought the kit from vb it fit real good. It still needs insulation but is a quiter than it was and looks very nice. since my vinl was shot.
  11. I think it was oct issue of hot rod. They put a super charger from a 350 on it and the only mod was to cut the tube shorter for the smaller engine.
  12. mine has a locking cap that fits under door
  13. I saw the raditor fan come off once. It was instering went through alot of parts and the hood
  14. update I got it fixed. It was a bad voltage reg but it was in the alt. replaced it worked fine shows what you can find out at shucks.
  15. sorry its a 78 280z 2+2 I already took it to shucks and they said that it was good.
  16. I need some help here its driving me crazy. It will not charge unless I rev it to 4500 or more then it will charge even at idle. For a while then it drops to 12 v and the red light comes on and a relay under the seat chatters then you have to keep it reved up and its barly charing. Heed help have to fix it tommrrow. please help. please.
  17. I have most of the heater box and stuff you need. Also if you need a hand I live in tocama and have removed and fixed both of mine.
  18. Hey guys Iam realy new to these inline swaps how hard is it to put in the old skyline motor. Its the duel overhead cam and turbo. What do I need and how much should I pay for the engine? thanx jason
  19. I have an intake and all the stuff you need. Where do you live?
  20. Try to turn the rotor by hand if you can turn it that is probly whay happened
  21. I had that happen to me once it turned out that the gear had broken the roll pin that turns the dissy when the gear turns. hope that helps
  22. I just got a car with that intake on it and it does have the webbing built in first one that I have seen.
  23. get the r200 rearend and the trans for a backup.
  24. I just bought a 78 280z and the head lights and blinkers dont work. But the parking and brake lights do. Any thoughts would be very helpful. Hope I posted this in the correct place. thanx in advance
  25. pete I had the same problem. I went to an accel cap and rotor. the other one i had melted the carbon rod in the center of the cap it took me a while to figure out what was happening because I couldn't see where it was until all the carbon gone. It started in side the cap. I got my cap at shucks, kargen or cecker. depending on what part of the country your are from
