after replacing the bushings, dont tighten them up all the way. take it to a shop with an alignment rack, lift it, tighten them up while the wheels are touching the rack. all done.
This is taken directly from the fuel injector/swap sticky.
Toyota Supra 1987-1992 - This is an o-ring injector 11mm. Injector electrical clips need modification or swap. Use stock seals at manifold and not the Supra seals. Year/Model/CC/ Impedence/Part#/Color
Turbo / 440 / Low / Black
Non Turbo / 315 / High / Green (stay away from yellow ones they are 295cc)
i just bought 4 injectors said to be from an 87 t2. but they are orange. the sticky on injectors says the orange ones are from 84-85 and are low imp 680ccs. these injectors im looking at now are said to be from an 86-88 N/T. they are also orange. anybody know? thanks for the help.
http://cgi.ebay.com/ebaymotors/1986-88-Mazda-RX7-RX-7-Fuel-Injectors-NT-Center-Mount_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el1262QQcategoryZ33554QQihZ016QQitemZ260216956039QQtcZphoto
come to think of it......the injectors in my n/t fc3s are orange. is the sticky wrong?
if you want to use rx7 550s you dont have to drill. take the pintle cap off the injector and use the stock manifolds' injector seals. thats what im doing.
if you can reset the ecu, the easiest and fastest way would be to d/c the battery completely and touch the positive cable to the ground cable for 30 seconds. if anything is stored in there that should take care of it.
nope. thats vented. using zx rotors and 89 toyota 4wd calipers(because they were vented.) i just dont know if they will bolt on to the s130s like the 79-83 calipers bolt on to the s30s.
i think only the autos were r180s, that should be an r200 in yours. theres a sticky in the drivetrain section.
Differential / CV / LSD / HP / Torque / R160 / R180 / R200 / R230 / Diff Mount
they are adequate for stock brakes. i just want it to stop like my fc3s. my fc has 4 pistons stock. it actually hurts to brake in that thing. theres absolutely nothing wrong with the stock setup. it actually stops quite well. i dont know. im still up in the air about it.
thanks you for the input. im really interested in finding a way to get the toyota calipers to work on my car since i can get reman calipers and pads for like $100 total.
