1rad280
Posts posted by 1rad280
After looking at my wires I wiggled the wire going into the turn switch and the right side started working but the left didnt.
Can there be a filter added befor the fuel pump on my 76 280 or will that burn the pump up. sorry about the title.
This one is green thats all you can see and it very fast if you didnt know what it was you wouldnt notice it.
I was watching the T.V., an insurance commercial came on and I cought a glance of a green 280z and my girl friend said I just had the 280z on my mind, but good thing for Tivo I rewound it and there it was. If you could only see the look on my girlfriends face. Has anyone seen this commercial?
My turn signals are inop not my brake lights or my reverse lights.
Have you replaces the canister?
yes the canister. Does you reverse lights work?
I check all of my bulb on my 280z and found that none of my turn signals worked no blinking noise nothing, so I started with new bulb and nothing changed, I replaced the flasher relay nothing changed. What should I check now?
What should I use to clean and seal my gas tank on my 76 280z?
My balast resistor has a black and white wire that is hot when the key ON. A black and blue wire has power only when cranking the engine and another black and white wire that goes to a capasitor. When I crank the engine no spark from the coil but when the key is on ACC the coil wire sparks. Any Ideas?
I have a 1976 datsun 280z I cant figure out how to wire run to my balast to my promaster coil and to my mallory unilite distributor.I have 2 black with white stripes,a blue wire,and a black with blue stripe going to ballast.I know the blue goes to the neg side of the coil and a white with black stripe goes to the positive side but what about the Green,brown,and red that originaly went to the dizzy? If anyone can help or send me pics it would be great.
Does anyone know wire diagram or have pictures of the wires and ballast for a 1976 280z
Does anyone know how to hook a mallory dist with stock 1975 280 wires and what does the red, brown ,green wired that come out of the terminal block do?
I need a picture to reference,I know how they run but not were they run but Im replacing the hoses with new and no one has them.I have to make them myself out of left overs I have from other jobs.
Does anyone have a picture of the throttle body coolant pipe on a L28e and how it runs? Thanks
thank you
Thanks, I wasnt thinking.
Does anyone know how to hook up a mallory dist and mallory coil box, in a 1976 datsun 280z. Mostly the dist. I think can figure out the coil.
What do you mean?
What do I have to do to replace my factory 280z l28 throttle body with a nissan ka tb?
I have a 280z with a mallory dist. large coil box,and a header. What kind of injectors can I upgrade to?
Does anyone want to buy another weber setup. I will sell for 1000obo.
here is a great small block.
Head Gasket? Just Throwing It Out There.
1976 280z no injector pulse
in Trouble Shooting / General Engine
Posted
I have got my 280z started but only if pour gas in it I have gas to all my lines but my injectors are not clicking any ideas?
