clocker
Everything posted by clocker
  1. This is an issue that's on my "Investigate at the Junkyard" list as well. Our mirror is in fine shape but I'd like a more modern unit that incorporates the map/dome lights into the mirror mount, where the light might actually prove useful. (Also, in our case, we're using a roof mounted antenna which requires moving the original dome lamp anyway...) I've yet to seriously look into this, so I have no specific recommendations or suggestions other than to look at 80/early90's cars for potential donors. Later units will probably have all sorts of extra electronic gizmos incorporated; I'm not interested but maybe you are. Something like the unit in my 2nd gen RX7 is what I'm talking about but as I said, I'm not familiar with the structure up there yet, so I'm not sure what I have to work with.
  2. The weather sprites gifted us with an unseasonably warm weekend and Sigfrid and I took full advantage. We started here: By Sunday night we were here: We are calling her good for the dip, any further prep would be useless when slathered with the thick matte coating. In the future should we decide to get real paint, we've gotten the body to a good start point for a real pro to work with and done no permanent harm. At least the old "urban camo" faded paint is gone and we can finally see the body for what it is. The Super Bowl will eat up next weekend, we hope to apply the dip the weekend following, weather permitting. The interior will then be cleaned up and a final beauty coat of bedliner applied. Let everything cure for a week and progress can begin again. I'd like to have the chassis wiring complete by end of February but we'll see how that goes.
  3. About RHD... I've owned a few British RHD cars and didn't find the "wrong hand" shifting to be a big deal, even when switching between that and a normal car. A few minutes to acclimate and Bob's your uncle. The downsides are that drive thrus are out of the question and visibility in traffic is awful, especially given the prevalence of giant SUVs lumbering around. As for the desirability of the various cars you've mentioned, I'd either go for the Fairlady or the FD.
  4. The PARK function is part of the motor, not the switch. If you think about it, it makes sense...how would the switch know where the blades are? Typically, it works kinda like this... Think of how the horn signal is transferred to the steering wheel, a spring loaded contact on a brass slipring. The wiper motor gets power just like that except there are two sliprings, one is intact/continuous, the second one is missing a segment. When you turn the switch OFF, the intact ring loses power but the "broken" one is still live, so the motor continues to run until the contact hits the missing segment and it finally stops. The drive spindle (output shaft) always stops in the same place relative to the gap in the segment and thus you have PARK.
  5. Well, it's Sunday morning and as I prepare to watch the Broncos/Patriots I thought I'd bring y'all up to speed. Yesterday went swimmingly. Neither Sigfrid nor his wife. Alex were terribly impressed with my dipped samples. Alex, who is amazingly cooperative with our garage adventures but at the same time totally uninterested, only likes "shiny" paint. Fair enough, I'd like that too. Sigfrid could see the advantages but still harbored hopes of a driveway done gloss coating, was harder to convince. So, while Sigfrid prepped the doors (the final major pieces to be done), I performed a more direct experiment. This was my hypothesis: -Given our equipment and facilities (very little and the driveway) we are not capable of prepping to an acceptable level. We can get things clean and smooth but not straight and the darker the color and higher the gloss, the more critical "straight" becomes. -All of our work to date -and it's quite a lot, really- has brought the chassis to a level perfectly suitable for a thick, slightly textured, matte finish like Plastidip but not even close for a "real" paint. -If one can ignore the custom/conditioning of what a car is supposed to look like (i.e., "bright and shiny"), a matte finish can be just as attractive as regular paint and in fact, has several advantages. More about that later. I decided to take the car just as she sat and spray a test panel on it. I wanted a spot that covered some of our bodyfiller work, some contouring and would be fairly easy to remove afterwords. Here is the test area (the rectangle behind the gas filler door): This covers where we deleted a sidemarker light and filled a bumper mount capture nut. The space got 5 coats of dip. It had been sanded to 150 grit only and washed before paint. We let the dip side dry for a few hours and then...attacked it. We keyed the dip, intentionally scratched through the coating (surprisingly difficult to do) and then sprayed over the damage with a few heavy coats. Plastidip melts into itself and after about an hour of dry time, the scratch was basically invisible from a slight distance. Careful examination shows the outline of the damage (because there is a difference in coating thickness) but the matte finish hides it very convincingly. If one built up the scratch/ding with a brush and then sprayed a final coat over the whole area, it'd be damn near invisible. A few hours later we peeled the whole thing off and yes, it actually does remove as easily as the videos show. Pretty incredible. Keep in mind that Plastidip is supposed to cure for a day before handling and we only gave it a few hours before attempting to destroy it...and it still worked very well. Sigfrid and I are finally on the same page...it's black dip for now. Here's the plan. We moved all the removable body panels into the attic. They have all (except the doors) been sanded,cleaned, bedlinered (on the inside) and primered. This frees up a lot of space, means we needn't tiptoe around finish painted panels and isolates the chassis as a "long term" test bed for the dip. As we continue work we can monitor how the finish looks and holds up to casual abuse. In spring, as the weather warms and the car has neared assembly completion (he says optimistically), we can paint and install all the panels individually and maybe even a fresh touch up spray of the chassis. My local Ace carries a full range of Plastidip (they just put in a standalone display) and sells gallons for $90. We're told we need between 3-4 gallons for the car. Sigfrid went online and ordered a four gallon pack (with extra prepaint "conditioner", whatever that is) for $226 shipped and it'll be here this week. Sorry, Ace. We'll spend a day on a few minor detail areas and get her cleaned up, then wait for a nice day to shoot the dip. I'm hoping to finish by end of this month. Meanwhile, the mirrors showed up. These are cheap (which is why I felt comfortable gambling on 'em), eBay "Spoon style"(no clue what that means) mirrors for a Honda Civic. Some rough measuring in the junkyard showed that the triangle corner of the window frames was very close between the two cars and the whole thing was under $25, so what the hey? Mounting them should be technically straightforward but I have no idea how they'll look or what visibility will be like...we'll just have to see. Finally, here is a terrible and not very useful shot of Sigfrid's favorite spot: He's worked so hard on this driprail area and it's turning out very well. It should completely disappear when finished and that is the whole idea. Good job, S. After the dip is sprayed I'm going to go over the interior with a coat of bedliner to make it all pretty black again, then the car will sit and cure for a while as I gear up for the electrical work. After the cabin wiring is done, we'll layer the interior with Fatmat or Dynamat or something and begin interior install. We'd both really like a Megasquirt and hope we can score a good deal before it's time for engine wiring but we can deal with the stock ECU if necessary at the beginning. Our long malaise has ended and we're moving again.
  6. Well, possibly better but not "all good". That giant hole in the shroud only provided an close/less obstructed air source for the fan than pulling through the radiator matrix. You'll certainly get better flow through at speed (above @40mph having NO shroud/fan would be ideal) but in heavy slow traffic I'll bet it works worse.
  7. We bumble forward, oblivious to both weather and lack of facilities. After two weeks of frigid cold, Denver is back to more normal winter weather and Sigfrid and I took full advantage. Speaking as a paint/bodywork ignoramus... This shit be hard. Not only are we woefully underequipped for the job but we lack the experience necessary to properly parse our progress. How good is good enough, what does this actually look like? Uncertainty has reignited our discussion of final finish...basically, are we capable of (and willing to) prep to the level necessary for a dark gloss paint? I've always thought NO, we are not, which is why I advocated for the Plastidip. The thick(er) matte finish would hide a multitude of flaws and it's much easier to remove if we later decide to upgrade to real paint. Sigfrid has always thought YES, we can, citing several cars he's already worked on. We needed to find out and decided on a test panel. We chose the windshield valence panel (it covers the wiper/fresh air intake cavity between the windshield base and the end of the hood) because it is the absolute worst case body panel being curved in every plane and stamped full of louvers. It's also very visible and any flaws are constantly on display to both the driver and any onlookers. We spent several hours, mostly on the louvers, and got it stripped nearly to bare metal. To the touch, it felt very good. It was not: This pic, shot soon after the final wet coat, does not accurately show how crappy the panel really looks. There are waves, micro-dings and wrinkles that suddenly jump out and plainly show how much further we'd have to go to achieve even a bad paint job. But wait an hour and let the paint dry: Things get a lot better. With a flat/satin finish the damn thing looks great. Well, maybe not great but certainly acceptable. To me, at least. I'll be moving on to part two of the experiment this week. I've brought the two inspection panels home with me and will spray them both in black primer. One will then get several coats (apparently, seven is the preferred number) of Plastidip and we'll see what it looks like finally. I'll eventually try to peel the dip off, to confirm it actually works as advertised. We sanded and painted the hood: ...because once Sigfrid gets going, he's hard to stop. The sugarscoops are also sanded, leaving the doors as the last parts to deal with. I changed my mind and decided to fully strip the doors now, attempting to minimize handling post-paint. We've begun the hole repair process where the mirrors used to mount and the jambs have been wirebrushed. The insides of the doors were remarkably clean and all the drain holes were clear...I have no idea why or how. Should we decide on Plastidip, our prep is well on the way to completion. If we want paint, we've barely started. Discounting the amount of labor involved (hard to do...) and the extra cost (even harder...), I object to paint right now as it completely warps the parameters we'd set for this first stage of the project. Remember, we've never had the car fully assembled and in running condition and given Sigfrid's penchant for power, I'd say it's a certainty that a swap of some sort is imminent. Plus, we're not sure what we're going to do with the body in terms of styling...flares, skirts, wings, bumpers...have no idea yet. To invest a big(ger) chunk of cash into paint right now and then have to tippytoe around "good" paint as we continue the mechanical work just doesn't make sense to me. Besides, I've always kind of seen the car as a "gentleman's rat rod" anyway. I want her clean, straight and functional more than I want shiny. The freedom from worry that a finish like platidip can provide is quite liberating. It's a freedom that extends beyond the obvious like rock chips and door dings, what it really is is an admission and acceptance that there will be a stage two, what we do now is neither final nor irrevocable. (Or terribly expensive...) No matter what we finally decide, yesterday's paint playtime was fun and instructive, a welcome break from the tedium of sanding.
  8. Finally, a front airdam/valence: This completes the main body although we're considering some add-ons like flares and sideskirts. Those will wait till the metal is complete and all one color so we can see what we have here.
  9. Yesterday was 60° and sunny, this morning it's 25° and preparing to snow. This whiplash weather makes planning a challenge, we did take advantage though and the project lurches forward. Sigfrid is driving the bus through this stage, I just do what he tells me and hope for the best. I find this stage of paint prep to be very confusing. It all basically looks like hell until the first primer coat is applied and I haven't the experience to know what "good enough" is, so he is handling the big stuff and I'm doing the scutwork. Yesterday, "scutwork" = the hatch jamb and the hatch itself. After eight hours I'm about 75% done, it's absurdly time consuming (better tooling would help) but coming along nicely, I think. Two things make it difficult...the jamb itself is very convoluted and complex, so lots of hand sanding is required and the multiple coats of paint are in every crevice and crack and must be removed. I also found the first (and only) evidence of rust repair as I worked on the bottom of the jamb (the part above the taillamps). The drainage of the hatch is terrible originally and the fact that water pools right where there are overlapping panels just invites rot. I was finding bondo where it wasn't expected and further sanding exposed a patch panel had been cut in and welded. It's not really a bad repair (could have been riveted/glued) and it's not structural, so we'll just skim over it again and carry on. A half day or so should wind the jamb up. Meanwhile, Sigfrid has been concentrating on the two main problem areas of the main chassis...the rear valence and the drip rails. The rear valence: This area was originally hidden by the elephantine safety bumper (seriously, the bumper and it's shocks/mounts had to weigh 75lbs. at least) and Datsun made absolutely no effort to make it look good, so there is a lot of covering up to be done. Serious guys would cut that valence out and fab in a whole new unmarked panel but since we're just two shadetree rubes, it's JB weld and bondo for us. If it looks too crappy, there are aftermarket rear bumper/valence panels that cover the whole area and could hide our incompetence. We shall see. The drip rails have always been a focal point for Sigfrid and they are finally shaping up. The original stainless trim really dates the car we think, so it's gone. The rails were ground down as far as possible (there are spot welds holding the roof panel to the doorframes) and then bondo was filleted in to make a smooth transition. Again, this is a "wait and see" kinda thing. I hope it works out but fear that body flex might pop the filler right out. I'm sure it'll be fine for a while. So, the main body is about 75% done, the fenders and inspection panels are done, the hood is half finished (the underside is bedlinered, the top hasn't been touched), the windshield valence has been stripped but needs sanding and the sugarscoops haven't been touched. The new front airdam/valence is scheduled to arrive today. Of the remaining panels, the sugarscoops will probably take the longest because they'll require mostly hand sanding. We figure three more days to paint. Of course, between the weather and Sigfrid's return to a normal work schedule, those three days may be spread over a month or so. I'm going to try to expedite this as much as weather (and my tolerance for sanding) allows. I'd like the car at the paint shop by Feb. 1 if possible. Probably won't happen.
  10. Thank you, and a happy and prosperous New Year to ya'll. Progress on the Z has continued, albeit in fits and starts as weather permits. Yesterday, Sigfrid and I managed about 10 hours and we plan another full day on Friday (supposed to be 60°!). Sigfrid has a natural aptitude for bodywork and has taken the lead as I follow along trying to make his lot easier. Accordingly, I spent most of the day prepping the doors, primarily removing the cursed tar that everyone uses to adhere the inner door seals. This summer when the doors were first removed, the tar was very sticky and messy and I admit I just shoved it aside for "later" and "later" ended up being yesterday. Of course, now the tar was hard and frozen (well, kinda) and took much more effort to remove. My takeaway lesson here is that shit jobs remain shitty and time doesn't help. Anyway, all clean now, the jambs are ready for sanding as well. Although the door glass has been removed, the mechanism is still in place (as is the inner doorhandle/lock) and I'm going to leave it in place during the paint process. It needs removing for cleaning/lubing anyway and I'm afraid of losing stuff in storage, so it'll just get a little more crapped up before removal after paint. After paint I'll gut the door, bedliner the inside skin and install the mechanisms after they've been rehabbed. This may be a mistake, we'll see. Note that I said "after paint" above. S. decided he really wants paint (preferably black) instead of Plastidip. His money, his car, his decision...so be it. Not sure who he's been talking to but after the main prep/bodywork has been done and the car is in primer, the Z is getting towed away and painted. The turnaround is two weeks and we'll be responsible for the final wetsand/buffing of the clearcoat. This is all great but I have a couple of qualms. First, the color. I like black and think the Z would look great that color BUT 90% of the Z's I've seen in black look like crap. The problem is the sheer number of separate pieces, none of which were particularly straight or well aligned to begin with. There are nine panels that make up the nose (2 fenders, 2 inspection panels, 2 sugarscoops (headlight nacelles), the cowl valence, the hood and the lower front airdam (which we just ordered and will be here next week)) and although the overall shape is quite pleasing, the actual fit is not too good. Black just highlights all these flaws and the amount of bodywork necessary to "fix" it would be enormous and require more skill and experience than either of us possess. (Plus, I HATE bodywork). Also, whoever this painter is (and I have no reason to think he's not legit), he wants the car assembled for paint and I say "**** that noise" to that stipulation. I've spent too much time on chassis prep to get overspray on everything and I feel that things like the doors and hatch can only be properly painted when off the car. Besides, after the chassis is painted there will be a lot of time spent doing electrical work and actually getting the car running...none of which will require bodywork and indeed, will be easier without it. We can store the fresh painted bits in the attic where they'll be out of harms way till we are ready for them. I figure another 3-4 days of us both working should get us to the first primer coat. That will be interesting.
  11. Even better is a temp gauge with a sensor exposed directly to the coolant.
  12. That would be the first two weeks of August. Then the glaciers move back in. I have a friend who lives in L'Anse (was just up there in Sept.) and he has built a very stout Dodge Stealth. Unfortunately, there's really no place to drive very fast up there in the woods.
  13. Where in the UP did you find a car that hadn't been converted to haul logs?
  14. To whom and who says? You state that as a hard and fast rule, yet I factor the title very lightly.
  15. Brakes are easy, options abound. And thinking about the whole salvage title thing a bit more... Seems to me that how much weight you assign a salvage title is in direct proportion to the number of potential candidates and how far afield you're willing to roam. As we searched for our project car last summer, we saw several cars that were in that price range and not nearly as nice. But there were only about 5 or 6 cars to chose from at that time. Increasingly, it has to be a sellers market because the numbers are inevitably shrinking. Our previous project car, a V-8 FD RX7, had a salvage title and the insurance company didn't care, the DMV didn't care and we sold it within two weeks on CL. The title didn't seem to be an obstacle at all.
  16. There's no guarantee on the structural integrity of a "clean title" car either. It could be as damaged as a salvage car, they just didn't file a claim. My current 25 year old DD would be totalled out if the tail lights got trashed, replacement would be more than the insured value of the car. As long as the car has some sort of valid title, I tend to ignore whether it's salvaged or not (don't even get me started on how useless CarFax is...) and concentrate on what is actually before my eyes. Metal doesn't lie, unlike insurance companies and sellers.
  17. So far I've concentrated on the mechanical progress because that's the part I was most involved with but Sigfrid has been nibbling away on the bodywork. Because he is a normal human being with family/work obligations, he has far less time than I to devote to the project, so our progress has been increasingly lopsided. I was having too much fun indulging myself in the engine bay when I should have moved to the bodywork...winter was coming. With the whole front end stripped for bedliner, it was easy and logical to begin with those parts. The car was originally silver but had become orange and then two different burgundies over the years. It sat in Arizona for several years before coming to Colorado, the paint was overdosed on UV but the chassis as dry as a bone. I guess it was fortunate that none of the previous painters had done proper prep, especially on the hard to reach/see places. The first pressure wash literally blew the paint off the underside of the hood: I cut credit card shaped blanks from a sheet of styrene and used them to scrape most of the remaining paint off. The original factory silver was in very nice condition and only required some scuffing up before bedliner: Our car had at some point suffered a run in with something and our front grill, lower valence panels (we have the sides but no center) and the fenders all suffered some tweaking. We aren't worried about the grill/valence yet but the fenders were a priority. They were the first body panels we removed and I was fully expecting to see a compost pile marinating in the wheel>door cavity. Bit not so much as a leaf was found, the foam strip on the inside of the fender was intact, albeit dry rotted. They were easily tweaked to shape and the only corrosion was some minor pitting under the side marker lights. Sigfrid wanted to delete the markers anyway, so that was no biggie either. He scabbed metal plates to the inside of the cleaned fenders with JB Weld and then skimmed the outside with it as well. Minimal body filler will be required to finish it off. At least, that's the plan. Here are the fenders ready to go back on. Final sanding/fitting will happen when all the panels are installed:] All the glass has been removed: And all the hinges have been soda blasted. They were in excellent shape, very little pin wear although we did have to replace one detent roller (driver side, of course). Some of the big holes have been filled- the marker lights and antenna- but there is still quite a bit to go, specifically, the rear valence below the (now deleted) rear bumper. Not sure yet how we'll deal with that area. I keep saying we're "not sure" about a lot of things because I have a hard time seeing the car with the blotchy paint distorting the view. Once she's a solid/consistent color it'll be a lot easier to visualize where she might go. Also during this time, we lost two weeks of prime weather as Sigfrid had his roof replaced. They took over the place and access was impossible. Then came Thanksgiving followed by a brutal arctic coldfront (five days of subzero/near zero weather with no sun...very unusual for us). And then of course, Christmas. This is to say that I'm not sure how much work will happen to the body till after the holidays. I'm going to retrieve the wiring harnesses from his garage attic, bring them here to warm up and start deciding what gets used and what doesn't. I have the electrical mostly figured out and have gathered the components to implement it but it's much easier to build it in the car and I don't want to do that with the car wide open and being sanded. Somehow we have to get this in primer. In the winter. Terrible planning.
  18. My perspective when I said his system was screwed up was this: Given that his car is carbed and has minimal engine electrics, the bulk of his electrical system consists of charging (which apparently works fine), lighting (which has been jury rigged to work) and wipers (which don't work at all). There are unknown switches and boxes wired into "a crazy mess" in the dash. The Z's electrical system is so rudimentary that having many things non/partially functional qualifies as "pretty bad", I would think.
  19. I have a question... Given the expense and fabrication involved in a proper HID conversion, is the final result really that much better than a good set of H4 lenses/bulbs supplemented with proper driving lights? I would enjoy the modding aspect of the conversion and look forward to seeing how you guys integrate the Mini/Fiat/whatever units into the sugarscoops, I'm just curious how you think the "bang per buck" ratio works out.
  20. Access to that technology would be cool and probably result in a best case outcome but as you note, the price would be impractical for all but the most rabid. Far more practical from a monetary perspective would be the "new Hyundai" donor vehicle route. Not only would the newer donor (which is not necessarily a Hyundai, obviously) have less wear due to age but I'd guess also less wear because everything these days has power steering, which must lessen the stress on the splined shafts. I'm sure there would be myriad details to attend to but one I can imagine immediately would be that the Z steering wheel/hub would probably not the fit new shaft. Most all the newerish cars in the junkyard have a smaller shaft the the Z.
  21. I would suspect a wear issue and I completely agree that worn splines cannot be "repaired". IF it is wear though, it would seem that a low mileage replacement might be an improvement and failing that, a column from a much newer car might do the trick.
  22. So, just to clarify... Your position as a "certified technician/engineer" is that play in the steering shaft cannot be addressed without compromising crash protection?
  23. My, that seems rather harsh. I can only assume that English is your third language because you consistently fail to acknowledge that I HAVE AGREED WITH YOU twice now that I don't think the JB weld "fix" was acceptable. What I don't get is why the only two choices are FIERY DEATH or "live with it". It seems possible that the OPs steering shafts are abnormally worn and a simple replacement would solve the problem. Should that not be the case (and who knows?), then I'd bet there are columns from some other car that could be fabbed in and solve the issue. Since collapsible columns have been federally mandated for decades, a swap would NOT compromise crash safety, so don't even try to hang me on that. I don't care (nor does the OP, I suspect) that you (and three others?) say to just ignore this issue. If it bothers him, it's worth at least exploring options. Apparently, exploring options does not fall under your "professional" capabilities, so I wonder why you continue to participate in this thread.
  24. Thank you, engine bay detailing is a particular fetish of mine. The overall aesthetic I aim for could be described as "optimised OEM", the appearance the factory guys might have achieved if the bean counters were removed from the equation. An example would be my dd 1990 Mazda RX-7, which started like this: And ended up like this: Or our swapped FD, which looked like this when I first saw her: And eventually morphed into this: To get to that state, I find it useful to try and understand how the designers approached the car and the decisions they faced. I mentioned that I'd printed a pic of our bay and studied it during my road trip (lots of time for rumination when you drive 3300 miles in 3 weeks...) but I'd also printed a shot of the 240z bay because it seemed obvious that all the emission stuff had just been layered on top of the earlier/simpler layout. I decided that the linchpin of the original layout had been the mechanical fuel pump. Its location at the front of the block lead to the fuel lines/filter being located all the way at the front of the bay and the fuel lines routed around the face of the valve cover. It all makes sense...until you remove the fuel pump from the engine block, at which point it makes no sense at all. I also figured that Nissan was well into development of the next gen ZX by this time , so rather than redesign the bay, they just tacked in brackets and components wherever there was space until we end up with the nightmare that is the 280z. And I never did figure out why anyone thought that a hybrid mechanical/vacuum control of the HVAC was a good idea. With our bay stripped and only the basic block left, I immediately saw that there were lots of extra mount points that we probably wouldn't be using but I decided to leave them in place until I knew they wouldn't be useful. I should have deleted the firewall bracket for the throttle linkage right then- I KNEW that wasn't staying- but waited till later. (I never have figured out why the Z has a monkey motion mechanical throttle linkage. It seems needlessly complicated and even in 1970 most cars used a cable, so the "tech" was obviously available. It's almost like a design exercise to see if it "could", rather than "should", be done because I can see no advantage to it.) As long as I'm on the subject, here's how I adapted the gas pedal to accept a cable. After removing pedal assembly, I saw that all I really needed to do was remove the original "ball" and put a small L-bracket in its place. I figured I'd use 5mm hardware to attach the bracket, so I used a 5mm drill to ream out the ball stud to remove it. Perusing the hardware section of my local Ace Hardware Racing Supply, I found a stunningly perfect piece...a 5mm studded bracket used to hold shelves in knockdown furniture. It was $.89. The stud slid right into the hole I'd made and was peened over to fix it in place. Then a hole was drilled for the cable (along with a slot for install) and I was done. Total time, about fifteen minutes. I used a Toyota cable because they use a very simple clip to retain the cable at the firewall...it fits perfectly to the stock firewall hole and the one I got was extra long, so I could fit it to the throttle body and correct the length/freeplay to suit. It works very well, pedal action is very smooth and linear. A bit of fiddling with the pedal stop screw and I had full opening of the throttle plate just as the pedal hits the stop. Don't think I could have done much better. I flipped the 240SX throttle body upside down so the cable pull was on the outside of the engine (rather than nestled next to the distributor)...this put the cable run on the outside edge of the intake manifold and resulted in an almost perfectly straight path from the firewall to the throttle body. Flipping the body meant the original cable wheel was upside down (and thus, reversed from what I needed), so I pulled some likely candidates from the junkyard and modded one to suit. I also machined and installed (press fit with JB Weld) a bung on the intake bell of the throttle body to feed the intake on the valve cover. This essentially duplicates the stock system but doesn't require a rubber intake boot with a hose fitting. Currently using a boot from a Volvo but that may change as we finalize what MAF (or AFM, maybe?) we'll be using. Right now she's mocked up with the MAF from a RX-7.
  25. I'd think that having a completely fucked up electrical system would be more annoying than not being aware of static discharge but you'll have that from time to time, I suppose.
