Story :
I bought my first Z car about a month ago. Owner claim the car had not started since 2000.
I drained all the gas tank. No rust came out, lucky. However, most of the fuel hose melted and messed up the pump. I changed the pump to MSD 2225, changed all the fuel hose around the pump, and fuel hose around the filter. Blow air to return line to make sure no stuck. blow air to feeding line make sure no stuck. Car started and ran but hesitate around 2000 RPM.
I checked MAF, TPS, cleaned both. All good, Suspect either fuel damper or fuel filter clog up ( I didn't change the fuel filter yet)
And now the problem:
I disconnect all the spark wire, disconnect distributor wire on the distributor side and still plug at the ignition side and left it hang around the engine compartment. Ran power thru the cold start valve to release fuel pressure.
After that, I change the fuel filter, installed inline fuel pressure gauge after the fuel filter,
Crank the engine to make sure no leak, engine didn't start , of course all spark plug wire unplug. I totally forgot that I unplugged all the spark plug wires and crank it couple more time. Fuel pressure reading 32 PSI indicated fuel pump worked.
I plugged all the spark wires back as of diagram 1 5 3 6 2 4 . And I couldn't get injector to tap again.
I checked both relay on driver side, cold start valve. Test fusable link, all good. Test the ignition coil , get reading of 12V.
My question is : did I flood the injectors when I cranked that many time? and cause it to damaged?
The ignition coil wire might have touch the frame and short out the fuse or relay somewhere? , if it posible.
I didn't test the ECU or the drop resistor yet. I searched but could't find similar topic relate to my dumb problem. Most of topic related to AFM and pump relay.
Please help as I live in apartment and park my car on street, I have to push my car around 1 every 2 days to avoid ticket from city.
