Everything posted by 10HBMartian
After the wiring I got the dash in and started on the interior stuff. I make carbon fiber panels for the S30 platform. i havent put one in this one yet, but i plan to later. I got a few goodies like a new steering wheel and some mirrors. not oem datsun mirrors. but its just for now. I decided to only put one on the driver side. I got some free toyota starion seats from a friend for it. decided they were better than the 30th anniversary camaro ones in it before.
So First thing I set out to do after the motor was dropped in was get it wired and running right. I spent nearly 3 months running through wiring diagrams. figuring out the switch positions, and all accesories. I wanted to make sure I would have to reenter the wiring system for at least another 30 years. haha
Hey guys I have a 260Z ive been working on for about a year. It has been gone through completely. everything is new or refurbished on it. The previous owner did an amazing job with the body work. All I did was finalize the LS swap and pretty much anything else. When I got her she was basically a rolling shell. It originally was going to have a 2JZ swapped in it. But I had bigger plans. My friend fabbed up some custom motor mounts for the LS. It places it 4 inches lower and 2 inches further back than any other kit out there. its practically a 50/50 balance now. only around 50-60 extra pounds over the original motor. I worked for a few months to get the wiring done on it. everything electrical works. I even did the honda windshield motor upgrade. completely fabbed up my own heater system. The amount of work ive put in this thing is ridiculous. Below is a list of things that went into the build. I didnt get too many pics when the motor was dropped in, but ive got plenty of pics of the rest of the build. SPECS Heads :GM 799s Ported & polished Block: GM LQ4 New GM head gaskets/ blasted chem bathed and rehoned. Intake: Edelbrock 29087 Victor Jr LS1/ LS Carb spacer Carb: Holley 750 CFM double pumper Ignition: MSD 6LS Fuel intro: ¼ inch aluminum line paired with Carter Competition Series Electric Fuel Pump 100 gph Free Flow , 6-8 psi output/ Standby mr gasket electric inline pump installed $320.00 Valves/ retainers: GM OEM LS6 Cam: GM LS-7 Headers: JTR 1-3/4" primary tubes, 3" collector Exhaust: 2.5 inch straight through to an 18 inch crossover muffler back to 2.5 to rear. Trans: 700R4 with transgo shift kit and B&M pro series ratchet shifter 2400 Dacco stall converter Diff: R200 with OBX lsd and hardened washers installed Stock rebuilt axles EXTERIOR Body : Fully shaved bumpers. Sand blasted undercoated. painted New rubbers on all windows Dash/ din steering wheel Z store cover ,full Doors Panels and hardware mirrors etc. Wheels: Rota RBR 17x7.5, 17x9, bridgestone blizzak lm22, mickey tompson drag radials Spoiler: BRE front air dam, custom rear spoiler Wiring: Keep it clean wiring harness. 21 circuit. Misc: All other random things. Bolts, wires, connectors, fuel cell, roll cage, switches, radiator, fans, intake, brakes, wheel spacers, misc electronics, etc. new , replaced/ refurbished
cost for an LSx 240Z swap
10HBMartian replied to hachikid's topic in Gen III & IV Chevy V8Z Tech Board
this is where I am so far. its not everything. and I do 90% of work on it myself. So no labor. Heads GM 799s Port & polish $500.00 Block GM LQ4 New felpro head gaskets New felpro head gaskets $2,200.00 Intake Edelbrock 29087 Victor Jr LS1/ LS Carb spacer $300.00 Carb Holley 750 CFM double pumper stock $420.00 Ignition MSD 6LS Programmed accordingly $350.00 Fuel intro ¼ inch aluminum line paired with Carter Competition Series Electric Fuel Pump 100 gph Free Flow , 6-8 psi output Standby mr gasket electric inline pump installed $320.00 Valves/ retainers LS6 equavilent Stock $400.00 Cam The real question lays here. UPGRADE stock Gms Hot Cam install eventually Headers JTR 1-3/4" primary tubes, 3" collector $500.00 Exhaust 2.5 inch straight through to an 18 inch crossover muffler back to 2.5 to rear. custom $500.00 Trans 700R4 with transgo shift kit and B&M pro series ratchet shifter 2500 stall converter $1,200.00 Diff R200 with OBX lsd and hardened washers installed. Stock rebuilt axels $700.00 EXTERIOR Body Fully shaved bumpers. Sand blasted undercoated. painted New rubbers on all windows $7,200.00 Seats Nothing special. $0.00 Dash/ din steering wheel Z store cover ,full $220.00 Doors Panels and hardware mirrors etc. $400.00 Wheels Rota RBR 17x7.5, 17x9, bridgestone blizzak lm22, mickey tompson drag radials $1,800.00 Spoilers BRE front air dam, custom rear spoiler $320.00 Wiring Keep it clean wiring harness. 21circut $300.00 Misc. All other randon things. Bolts, wires, connectors, fuel cell, roll cage, switches, tape, shrink wrap, fluids, radiator, fans, intake, loom, steering supplies, brakes, wheel spacers, etc etc. $3,200.00 Total Rough estimate on most parts. This is not including the labor I put in and the things i had laying around the shop while building the car. $20,830.00 -
ok so a week ago i tried to wire in a radio in my 77 280z. it ended up not working right so i just pulled it back out. a few days later it failed to start. i charged the battery all night then it was working properly for a few more days. then it just wouldnt crank up unless jumped. i replaced the battery and alternator. and checked connections everywhere. it ran fine for a while. then the other day it drained itself dry. i jumped it. it ran fine for a few then slowly lost charge. every since i put on the new alternator it has the charge light on on the dash. its just a stock 280z alternator from advanced auto. i unplugged every thing under the dash that wasnt necissary like the heater blower, radio harness just in case it had a short. i looked at the little relay onder the passenger seat too. it looked fine no shorts. im at my end with this electrical monster and any ideas would help greatly. i looked around on here but nothing specific to my case turned up. thanks
ok so i fixed the problem. turns out it was a melted fuse housing. i just re sodered the old fuse holder to a new wire. installed a new fuse and then it all worked properly. but now the damn turn signals wont work. the hazards work fine so i think it might be a switch. lol did i mention how much i hate electrical. especially on old cars. im going to custom fab a newer fuse holder in there so i dont have the blown fuse problem so much.
oh yeah this is what im going for. a little bit of flat paint can go a long way with the right creativity!
motor pics, raw after i installed the griffin 3 core radiator and the E-fan and thermostat. took all the ac stuff out as well. (if any one wants it they are free to pick it up.)
and this is how you lower you datsun for 50$. go to your local fasten all and buy 4 two piece shaft clamps ( btw they are rated for 6000 lbs each). place it on the strut tube where you ant to drop it too. I chose to lower it 3 inches in the rear and 4 in the front. cut off the old ring at the bottom. grind the weld away, and walaaa. youve just lowered your z for 50$ and its actually safe.
the rear after i cleaned it out. not a single rust spot anywhere. oh the z was origionally from texas like me! explains the minimal rust anywhere on the car.
the origional owner gave me this turbo setup as well. idk if i want it to go on though. id much rather have a tripple carb setup or just tweak the FI setup to my liking and run megasquirt.
so here was the inside before i cleaned it out. needless to say the previous owner neglected her. there was only a small amount of rust on the passenger side floor board. suprisingly enough. the driver was perfect. i just cut it out and welded in some patches.
ok so ive had my z for a couple months now and i though id post some foward progress. i got it pretty much stock. not a whole lot done besides asthetics. i will slowly be going through it cleaning her up and making it run for autoX races eventually. well without further ado here it is.
I know there are plenty of posts about tail lights, and running lights, but trust me none fit my problems. So i have a 77 280z to start with. a few weeks ago my dash lights and brake lights stopped working. idk if the brake lights ever worked though. Just recently the running lights stopped working. I have headlights, blinkers, and hazards. Afte checking with a voltometer i can see the switch works properly, and the fuse is good for the brakes as well. When I push the pedal i get like 13V across the fuse, just nothing at the rear tail lights. i checked the bulb housing. I also took apart the passenger side and examined the wires. There was no sign of a short or ground anywhere there. I bought a new brake light switch just to see, that didnt fix it either. its weird. like i said the headlights work, and blinkers/ hazards too. just no brake lights running lights or dash lights. All fuses appear to be fine. any input would be nice thanks guys.
