lwrnclightner
Location
Edgewood MD
lwrnclightner's Achievements
0
I have a sds em-2 6f,,,, I have abandoned my build so I will be getting rid of all my turbo stuff. It is complete! Every single component. I even have the pully balancer with the pick up magnets already installed, Install manual, with a couple maps from prev owner. I am asking $450 + shipping&PP
I ran across this one today, may be just what the Dr. ordered!!! http://washingtondc.craigslist.org/nva/cto/4816272204.html
Thanks, thats what I thought, just wanted to be sure before I junped the gun.
I have the opportunity to pick up a new never used one for a really sweet price. I am on my cell and cant access the sticky, but I want to know if the 84 a/r turbine would kill my Low end. I know 63 a/r is optimal, but would 84 take the fun out of it? Stock block and p90a, will be going with 500ish injectors, large intercooler and meth injection,controlled by sds 2 fuel and spark..... If its not a good match for our engines then I will pass and buy the proper size... Thanks
Thanks fellas! Well what I now know is that the sds 2 doesn't use idle air control, so am I correct to assume that I will have to tweak idle air by adjusting the screw that holds opens the valve on the 240sx tb in sequence with the fuel adjustments that I dial into the sds controller? If so then I am really going to be an "old schooler"!
- 6 replies
- sds
- 240sx throttle bddy
(and 3 more)
Tagged with:
Ok, now I am starting to get the picture, well for the IAT anyway. So let's see if I have this right. If I plan on running a water/meth inj in addition to the intercooler, then the IAT sensor should be after both of them but as close to the throttle body as possible, am I on the right track there? Now I must admit that the idle air bypass has me a little confused, only because I will have the intake build that Senza Pari provides (if the group buy #2 ever kicks off). I will start to research exactly how the bypass works and what type of device I need to implement it. Here is what I will attempt to find, let me know what I am missing from my list... 1. What a idle air bypass looks like and where to obtain one (new???) 2. Where does it terminate to? 3. How is it controlled? When I brought this car, I had no idea that I would be learning all this fun stuff. I can't wait to get it running and feeling what it feels like to be in tune with your ride, to know whats going on inside and out.... To be one with my ride... Kudos to you guys for being here and pointing me in the right directions, as I go. Hey Tony D, you remember my first post,,, asking what these were?
- 6 replies
- sds
(and 3 more)
Tagged with:
I have been putting together the ingredients for my turbo swap, and it's coming together quite "Niftily" if you ask me (Noobest of the Noobs). 1. Anyway, I read through the sds install manual and today as I spread my kit out (just to admire it) that my sync magnet is mounted on the inner radius which is where the trigger magnets A,B,C are mounted. Now the pully is scribed with the outer radius and a hole drilled just next to this magnet which is where I assume it was originally designated to go. Now in my nooby brain I am thinking that this will screw up the trigger signal being picked up by the hall sensor and that it is not going to see a sync signal. Help me understand why this was done this way. I guess if this was done in error I can drill the magnet out and place a new one on the outer radius where the manual states it should be. 2. Can someone confirm or clarify for me if my inlet air temp sensor goes in the 1" spacer where the red arrow is pointing.. or does it go upstream of the throttle body? Thanks for any insight that you send my way! Lawrence
- 6 replies
- sds
(and 3 more)
Tagged with:
Is 2f worth getting me started, or should I hold out for a later version? My goal is a modest 300ish hp/tq range using a t3 04e 50trim garret. Sds seems a tad bit more straight forward and easier than megasquirt to me (noobest of noobs).. I originally posted asking would I be able to use the Ls1 coil set up I have waiting, but I am not able to find any finished projects with this combo. So sds 2f looks like it can do what I need....right? Thanks Lawrence
Found a manifold, this can be deleted...
Looking for a turbo exhaust for my conversion. Thanks, Lawrence 443 600-5297
Good deal for LS1 coil on plug set up?
lwrnclightner replied to lwrnclightner's topic in Ignition and Electrical
Never mind I found it, sorry about that. -
I tried to find the thread but I don't know the right way to do so.... exactly where do I go to find it???
