Everything posted by Tempered
Looking to buy a ford taurus fan, hopefully in good condition, the two speed model recommended by JTR for their conversion. PM Me or post here, either or. Thanks
Your In luck, I have the a t-5 bell housing I pulled off a 83 280zx from a junk yard, I'll PM ya too.
Here is my diamond.
74 260z build "From the middle forwards and backards!"
Tempered replied to Tempered's topic in S30 Series - 240z, 260z, 280z
Well, moving backwards a bit. My first car ever was a truck, a 1950 F-1 I bought in 1995 when I was 15. I sold it about 7 years ago after giving it a paint job and doing all the work and i've regretted it ever since. I bought it back two weeks ago and here she be! The original rouge 226 flat head, producing roughly 95 BHP! they did not take care of the vehicle for the most part as the paint on the engine had been good when I sold it. So for now the Z sits. I've gotten a little work done. Battery move is complete and the gas tank is back in. I wired the Holley fuel pump to a toggle switch to the Black-white wire off the ignition switch. -
Can poor ground weaken starting power?
Tempered replied to Tempered's topic in Ignition and Electrical
Copy That, thanks guys. I tried a test by jumping the battery from a running vehicle and it picked up a slight bit. The kit I used is the summit relocation kit so I believe he cable is 2 gauge, it's very thick. The ground to the disconnect is 2 gauge and from the switch to the frame is of common battery cable size. I don't have a meter to test out the connections but i'll get one soon. Thanks for the help. -
Hi there, I just finished installing a battery relocation kit. My ground runs from the battery to a disconnect switch to a spot on the frame. My car will turn over but it is very groggy. I know its possible my battery is dead but that would be really rare. The battery I use normally cranks like a beast and never falters. So.. I'm just curious if the weaker the ground connections the less power that will be transferred?? Or does it not matter, once you have a ground you're good. Thanks for any help.
Ok, tanks finally done, after numerous screw ups. I am somewhat versed sending units now. I have the wrong one, backwards in my tank. It's only going to show half full or so. Got my heads from the machine shop today!! Re-painting them to match the block of course. -
holy turbo. I couldn't help but picture the car causing a rift by going into warp speed when that baby kicks in! Sonic boom maybe? Very nice !
Fuel Sending unit/Tank question
well the bent one is the original one out of my 260z and is not going to be operable. The one I just purchased must be from a 240z style tank. This is the tank looks like. The whole mechanism is gummed up or sealed with the tank sealer. If I were to pull the bent arm out, strip off the sealer and replace the straight one, I might be in business. The 280z sending unit appears to have a bit more to it. -
I have a late model 260z and like a retard I did a re-seal kit with the sending unit still inside. I was able to get one off of a 260z off Hybrid here but I didn't specify early or late model. Well the design is a little different. Anyone have experience in this area. I'm not sure how the inside of the tank looks or anyone has ran into this. I still need to fit it in and see.. Here is a pic. I know I could probably change the arms, but i'm REALLY good at breaking things so I am going to wait on that one. New one is on the left, Original on the right.
A little update, I've wire wheeled the entire fuel tank and then used a POR 15 tank sealer kit. The sealer is hardening on its last 24 hours. I made a rookie mistake by putting the sealer in while the sending unit was inside, it has now hardened beyond use. I also POR 15'd the straps. Next I added onto my battery box move and mounted the fuel pump. The battery disconnect was moved to the battery box. The engine build is going slowly, a little bit each Sunday. All the way up to retapped the engine threads, tank mounted and finally got all of the pistons in. THEN when torquing the Connecting rods, most would not torque to 45 ft lbs, but kept going. My buddy thinks someone over tightened them the last time it was built and they stretched. So regardless the ARP connecting rod bolts arrived today. Some pics -
Any good condition fuel sending unit, whatever will work in a 74 260z tank. Live in Ceres California and will cover shipping. PM me or reply, either way I'll check frequently. Thanks
What starter do i need? T5 trans - sbc
Tempered replied to rustorbust's topic in Gen I & II Chevy V8 Tech Board
Yeah, in my conversion i'm doing the starter last, but i"ve been eyeballing this badboy. Not too bad. Fits both 153 & 168. The sale price had been 134.95 but it's now 149.95 $. http://store.summitracing.com/partdetail.asp?autofilter=1∂=SUM-829000&N=700+0&autoview=sku -
Damn that looks great. Thanks for the tip. I have a 77 as a donor car but i'm not sure if it's rust situation is in any better condition. But i'll be looking now. As far as harbor freight goes, i've been making bi-weekly trips lately. At the time I think I had just dropped $1k at the machine shop and was not looking to piss off my wife any further. I usually have many friends with all the right tools when in a tough spot, but I have the damn tank out so couldn't drive there. *update on motor. Got the first four pistons in the block, retapped all the bolt holes on the block, cleaned em out. Ran out of time but will finish motor next sunday most likely. -
Whats up panzer and ace! good to see we have some central valley Z'ers. I've been keeping an eye out on the road and have not see many rolling around. Do you guys ever get involved with the Z events from the Sac/bay area? I've been curious to see how many locals attend and look forward to road trippin. Thanks on the car, getting ready to assemble the motor in a couple of days. I'm still not sure if I want a Manual or AT. I'm not really a track racer and my experience with manuals and taking corners is a minimum. I'm also afraid a 5 speed with be torquey or jerky, trying to convince my wife to ride in it. heh ) -
Sorry about your car, I recommend getting a copy of the traffic collision report ASAP. The handling agency will charge you a small processing fee most likely. Well..... I know how California works, not sure where you're at but, some things might be similar. On the CHP 555, the driver the investigating officer believes to be at fault is always listed as P1(Party one) or D1 (driver one). If your listed as P2 or D2 you can possibly interpret that as not your fault. IF you get a copy of the report, look for the words "Primary Collision Factor" or PCF. This is usually determined by the Investigating officer. If it says something like "excessive speed" or the state vehicle code for speeding it could be reasoned that they think you were at fault (unless speed would apply to the manuever the lady was using prior to the collision). If it says something similar to "inattention" that could be either of the drivers, most likely the person who pulled out. I would look out for "Failure to yield" or any Vehicle Code section related to that. That would indicate her failure to yield to oncoming traffic, thus her being the primary collision factor. You can find all of your state codes online. The insurance company will get a copy of the collision report but it usually takes forever. In California an officer completing a collision report has 30 days to turn it in to the CHP. The most important thing about having a bunch of witnesses is that they give their witness statments AT the time of the collision while the initial officer is there. It builds credibility for his report. Ultimately the usual outcome of these incidents is determined by the opinion of main investigating officer. Now as far as braking, the formula's they use to determine speed is real basic and you could easily argue in court that their calculations were incorrect because they didn't take into account your vehicle type, weight, etc etc. They can usually only determine exact speed when there are straitions on the black marks and that is left from accelerating, not braking. Anywho, there are a bunch of areas to speculate on this incident, best thing to do is get a copy of the report ASAP. Good luck.
So now I'm caught up to my current status of the car. I figured I would handle the fuel pump and battery relocation before the V8 Swap to save down time. The damn spare tire area was rusted, leaking exhaust fumes so I decided to remove it, thinking I could build small trunk to mount my battery. First off, if you plan to do this, obviously use some kind of cutting tool. I didn't have one so I tried drilled the welds out. It took forever and I still needed a cutting tool to clean it up. Heres how it looks Now, the battery box relocation kit I got from summit is a little bigger than expected. and my ideas of a small trunk were crushed. So at this point there is the option of a fuel cell, No way, I enjoy using the filler from the rear side of the car and I'm afraid a fuel cell will fume up the inside of the car. At this point I drop the tank to deal with apparent rust issues with EVERYTHING. I'm also going to take it down to bare metal and repaint the tank after I reseal it with Por15 tank sealer. Tank gone So once the tanks gone, I'm figuring I can mount my new Holley Red pump to where the old electric return line pump is located. I am assuming the wiring will run the new pump correctly. I used the old bracket, cleaned it up added the pump. Since my battery is probably gonna be just above it I also mounted the disconnect switch. My buddy recommended using the disconnect on the negative cable. I kind of wanted it hidden as well so I thought this was the next best spot due to the ground going right there anyways. Same mount cleaned up with new additions. Currently this is my idea for my battery box. I plan on welding up the hole once I re install the gas tank because I have no welder and the nearest buddy is beyond pushing distance. So now that i'm moving the battery I decided to tackle a small hole under the old battery box. WHOOPS!! So I plan to section out all of the rust areas in the old battery tray area and weld it up with new metal. Any suggestions on this would be excellent since i'm doing it somewhat with no experience in this area. I do have some buddies who are pretty savy at this but I haven't spoken with them yet. -
So I had been wrestling with the issue of how to build the car, of course I wanted to go fast and for the most part i've already upgraded the brakes and suspension. I'm worrying about bodywork and paint last. I knew that if I spent a lot of money on an L28 I would in the long run still want to go faster in my thrill searching and probably spend more money on a V8. So my buddy had an old 60's corvette 327 he gave me. It had one piston go bad but he had the new piston. It has the double camel hump heads, new bearings, the block had been honed. So what the heck a FREE motor. My bad Decided to take the block down to the local machine show. They are a good shop with years of experience, so I trust them. They inform me the 327 has wear inside the bore. The camel hump heads have issues and need to be reworked as well. So, the guy was straight up and said if I wanted an engine that would last and not go out after 3000 miles, It would be wise to rebuild. So I decide to do it all nice and rebuild. The engine was hot tanked, bored over, new pistons, rings, already have the bearings. The shop hooked me up and gave me their price on all related parts, including gaskets, cam, timing chain, freeze plugs. I also had the engine balanced while it was there. So I just got that back. So here she is now and all her parts. I'm just starting to paint the block, still waiting for the heads to be finished. The shop said the engine will have compression just under 10:1 I yanked the cam out of the box, and it says "Crane Cams" I'm interpreting the specs as a 454/454 with a 280 advertised Duration, Is that decent? So Far i've aquired *Ceramic coated block hugger headers *Edelbrock Performer RPM Air Gap *HEI 57,000 volt distributor *95 amp 1 wire (powdercoated) alternator *Water pump *valve cover kit *engine bolt kit *FREE holley double pumper (needs rebuild) *Holley RED electric fuel pump *Summit battery to trunk kit *battery disconnect switch *JTR V8 conversion kit, Radiator hasn't arrived yet Some goodies Pictures -
Well after starting this thread tonight and seeing the actual money i've invested, i'm a little embarrassed and I think i'll stop. I'll just continue on up to my current vehicle state. Most recently i've had my interior finished by a shop because I tried to install it myself and I sucke. I did put some holes where they shouldn't be. The shop saved my butt, re upholstered my doors and seats and it looks great. The pictures dont do it justice so i'll try to update them. I later went down to the radio shop and got a new deck, some 6" speakers in the doors and 6x9's in the back, which I mounted through the carpet into the empty storage boxes. Not such a good idea. Finally purchased some JDM style fender mirrors. I had been waiting for some chrome ones to pop up. I followed the directions for a left hand drive and took some pictures of my measuring process hoping they may help someone else one day. The start I have more detailed outlines on my work computer, i'll add shortly. One major Mistake I made was in the diameter I drilled into the fender. The diameter of the plastic piece for the mirror was most likely metric, I had hoped that the next standard drill size up would work but now there is minor play and the mirrors can rotate, not too easily but enough for a bumpy road to rotate them. The finished product -
So then I saw the ROTA RB group buy and jumped on it quickly, getting 9's in front and 9.5's in the rear for $700.00. I went down to America's tire company after some research and spent $600 approx on new Z rated BF goodrich's, balance and locking lug nuts. Also Along the way I found a near brand new radiator in a 280Z at the junk yard and bought it for $80. It brought my temp gauge down nicely. Speaking of Gauges I bought the flame gauge covers for $22.00 off Ebay, even stained the gauge bulbs blue, but couldn't get a picture of that. The Sparco steering wheel was FREE off of a wrecked porsche at my buddy's junk yard. The adapater was flipping $72.00. -
So continuing on..... After going to Pick n Pull again I found a square port 6-1 header which I got for $30. The SU's I had weren't running too hot so I bought some used Weber DGV's with an intake off of Hybrid for $225. I got my buddy to help rebuild them at 24.95 a kit. I ordered the cheaper air cleaners from Redline Carbs for approx $40(losing my memory) and the throttle linkage kit $79.00. I purchased an MSD blaster coil kit from the local kragens at $49.00. From MSA I ordered the taylor plugs for $46.95. So it went from this To This Once I was running an open header, I took her down to the shop for an exhaust system. Went with a Magnaflow resonater along the tunnel and a stainless Magnaflow muffler out the back, it sounds so/so, $240. After I heard the twice pipes kit I kinda cried.(once again my fault for poor research) So later on I ordered front Cross drilled slotted rotors off of EBAY for $104 or so. I then changed my front disc over to kragens for the toyota four piston kit, also bought a caliper paint kit. I also purchased rebuild kits for the back drums, i'm guessing this was just under $200. For new shock/strut boots, Kragens charged $20 a pop! From MSA I purchased the Tokico non adjustable shocks/struts all the way around, The complete polyurethane bushing kit, upgraded sway bars, stainless steel brake lines, the pile-loop carpet kit, deck lid. The total came out to about $1500, just a bit over I believe. While doing the rebuild, I found an 85 200sx turbo and snagged the 4.11 R200 rear end. Went to a buddy's junk yard and got the axles for free. Took them down to the local shop and they were retrofitted with new greasable U-joints. That totaled out to $160. I totally disassembled the car, put all of the new goodies on, including the urethane bushings. Everything was cleaned and painted with rattle can flat black. -
Well Hello all, reporting in from the central valley of California. I've owned a couple of Z's prior, 94 300zx convertible, 85 300zx turbo and this is my first S30 car. I can already tell you I love it more than all the others. I'm a ways along in this build and i've been saving pics so I apologize for the flood. I'll also be running a total tally on the costs i've invested, showing how much a V8 conversion CAN be. So here we are, my 1974 260z (12/1974) which I purchased for $1450. I didn't know then but it was a big rust bucket and yes, I should have done more research. If you notice the chrome valve cover, I got it from pick n pull for $9. After I bought her I took her home and scrubbed her up. Then I tackled the interior, which was a mess. After pulling out the ripped carpet and non existent spare tire area I discovered rust and holes. I don't have after pictures but I stripped the interior, used a POR 15 starter Kit, POR 15 putty and got an extra pint for good measure totaling $77.75. Cleaned and sealed the complete floor area. I also ordered a roll of insulation off the internet for approximately $30.
Summit Block Huggers with JTR setup
I went with some unknown make block hugger headers from the Good Guys swap meet. Ceramic Coated with gaskets and collector's = $165.00. I pray they work. -
Tempered replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
Rota Rb's 17x9 and 17x9.5 BF goodrich G-force 245/40/17 on the front and 255/40/17 on the rear
