I've been at this build for two years threw the ups and downs, but this one may be the down that breaks me. I'm an l28et swap in my late model 260z(11/74). For the past two months I've been trying to get the car to crank and fire, with no luck. I have fuel and spark(will get to the spark in a second) but the car won't fire. Originally i thought traced the problem to my battery(optima red top), it had sat for almost a year and when I went to put it in the car it didn't start. So I thought simple enough, I would charge the battery. I charged the battery to full and it would crank, for a few times and then slowly die out. I had a friend give the battery a jump and I would get power, and then again crank and die out slowly like it was losing cranking power. I sent the battery, back for the warranty, and in the the time it took for them to send me a new battery I figured out I had a timing problem, where the oil pump shaft wasn't lined up correctly. I fixed the problem and aligned the shaft accordingly to the fsm(82 280zx). When the new battery arrived I had dropped it in turned the key and again tried to fire the car, but with no luck.
I suspected that there was a problem with the connection from the ignition switch, to the wire that connects to the starter, so i by passed it and tried jumping the starter. When i jumped the starter the motor cranks over and slowly loses cranking power, but again fails to fire. Here's the twist, if I jump the starter and the motor cranks over for a few seconds I can hook up the ignition wire back up to the starter, go back in the car and crank it over with the key for a while before it starts to slowly die out and lose cranking power. I thought maybe I have a bad starter, so I went and picked one up from kragen tonight and tried to start it again both with the key(which didn't work) and jumping the starter. When jumping the starter the motor again, cranks over for a few seconds strongly but slowly loses power and the cranking becomes weak. I verified the timing on the distributor, and that the cylinders were getting fuel. The spark is weird, by that I mean when I use the key to turn the ignition to the "ON" position the ecu light, fuel pump comes on to prime the fuel system, and you can hear a spark tick at about 2 second intervals(I also pulled a spark plugged and watched it do it). I almost sure that I'm not supposed to be getting a spark like that when the ignition switch is only turned to the "ON" position, I believe it should only spark when I turn the switch to the start position. I have no idea what can be causing this.
To add to all the madness, today i when I tried to start it by jumping the starter it started to crank and then all of a sudden it KEPT GOING even after i stopped jumping the starter. I rushed to turn the key to the off position and it kept going. Wires started to smoke in the engine bay and under the dash(f!*K) so i ran to the battery and disconnected the power wire and it stopped. On my car the battery is relocated to the hatch and the positive wire goes through a hole in the firewall directly to the starter stud, and the ground wire is hooked up to where the passenger seat belt bolt is on the body of the car. I haven't hooked up the battery again to see if everything thing was still working, lights, blower motor, headlights, etc... I', too scared to hook back up the battery to check everything, in fear that I might further damage the wiring. The only thing i can think of is something may be wrong with where I spliced my switched and 12v start connections for the F.I. harness that is drawing power. I have the yellow 12V wire from the F.I. harness spliced under the steering column into the stock 12v yellow and black wire, and the switch power wire(black/white) from the F.I. harness spliced into the stock black/white wire(ON) under the steering column. There is also a switched power wire coming from one of the relay in the engine bay spliced into another black/white wire i found in the stock harness in the engine bay.
I've came so far to give up on this thing now, but I don't know what else to do, the continuous cranking and smoking wire really threw a curve-ball at me and I am low on LOST. I'm in need of some help from someone in the Bay area that has done this swap, for some guidance. If you can help please pm me your contact information, Thanks. I don't think I can solve this "series of unfortunate events" over the forums ..........would love to be proven wrong
