ASA240Z
Everything posted by ASA240Z
  1. Lately I've noticed that the damper oil in my carbs are going down quite fast. Whats the reason that this is happening? Anyone have any recommendations on the type of oil I should try out?
  2. hey guys, i was wondering if anyone had any suggestions for keeping the SU carbs tuned. This has been happening for the past couple years and I'm finally getting fed up with it. It seems that every time I tune my carbs they work well, no smell, no leaning out, etc. But I'm always having to retune them every couple weeks, otherwise they begin to run rich. I was wondering is there was anything by loctite for example that would keep the adjustment screws etc in place, but not permanently. thanks
  3. lol I forgot about this thread... anyway I tried using the stubs from my Z but it doesnt want to grab the gear teeth in the diff. assuming the the stubs are stock with my year (72') would this mean that they're worn out, or the wrong part? Thanks
  4. To make things short, I bought a earlier R180 4.38 and im having trouble with the side shafts. I was goning to swap my side stubs by it does seen to hold and I dont get an power to the wheels. I found in the sticky about the various diffs that the earlier R180 diffs need some kind of mod to make the side shafts work: "Newer R180s are availabe from the 84-88 200SX and have a large K cast into the top of the housing. They can be used in the Z with some modifications. The newer diffs use a stub shaft that plugs into the diff and is retained by a circlip, and the older diffs used a bolt in stub shaft. CLIP IN AXLE VS BOLT IN AXLE R160s/180s There are two ways to use the newer R180s with the original side stub shafts and half shafts. One is to convert the diff to the bolt in axles. The part that the bolts connect to is called a button, and the procedure to swap the buttons into a K diff is described below. These same procecures hold for LSD carriers, but the disassembly of the LSD is a bit more complicated. The other is to modify the stubs to use a spring clip, and then clip the axles in. http://www.betamotorsports.com has taken the effort out of this procedure by performing all the machine work. Just buy the new stubs and clip them in." http://forums.hybridz.org/showthread.php?t=114798 First of all the article says that this diffs come for the SX's, mine is supposedly from the a nissan truck. Are these the same? Now, does the R180 that I have need this mod, or is there something else wrong with? I posted some pics on the diff I have...Also can some one post a pic of a diff that needs a spring clip for the stubs shafts to work, I not really sure what the difference looks like. Thanks
  5. last night my car wouldn't move when I shifted in gear or reverse. I noticed that when I put the car in gear and looked under the drive shaft is spinning. Earlier today I put the car on stands and then removed the axles. I then started up the car and put the car in gear. To my amazerment both flanges started to move forward, what the hell is going on here? Whats something stuck? Before yesterday the car has been started since about a year ago? This seems like a diff problem since I just swapped it out with a 4.38. Also before I swapped it I had to change the flanges on top and sides. Any ideas why this would happen? Allen
  6. Something like this? thank for your help.
  7. Hey guys, I'm installing the tokico blues/springs on my rear suspension. While I'm at it i was going to change the bushings. I was looking on MSA's website today add I noticed that they sell "Urethane Bump Stops" http://www.thezstore.com/page/TZS/PROD/PSDC06E/23-4196 Where exactely do these go on the suspension of the car, between the insulator and spring seat? And are these in the energy suspension master kit? pictures would be nice =) Thanks Allen
  8. Yesterday I finally finished the removal of the rear suspension on my 240Z. I plan to replace the bushing with a power suspension bushings, install tokico blues and springs, and exchange the stock 3.35? diff with a 4.38 diff (R-180). Now Im wondering if anyone knows how to remove the side stub shafts connected into the diff? Also does anyone know if the stubs between the stock diff is interchangeable with the 4.38(4.38 did not come with the stubs)? I've read of problems with swaping the stock diff with that of a 4.38. Sofar what I know is that the large K is on the casting. Also looking down into the side, I see the threads and futher down I see more threads for the bolts. Does this help? Thanks for the help! Allen
  9. Have you tried Corbeau racing seats? Their quality is very nice and I'm sure that they make brackets that bolt into the original location. http://www.corbeau.com/ Later, Allen
  10. you may of accidentaly placed the diode in the wrong drirection. I believe the arrow should be pointing towards the T connection on the alt, check if that is the problem. Hope that helps, Allen
  11. was up guys, I was looking and planning to upgrade my old volt reg and alternator with a 280zx alternator along with dumping my points with a electric setup. I was looking at my voltage reg and noticed this funny looking thing. can anyone tell me what it is? it was bolted right next to the reg. Also next and attached to my coil there another one or similar looking object. I looked in my books but really didn't find what I was looking for. Later, Allen
  12. 1 fast z thanks for the help, I very much appreciate it. As for the message from J. Soileau RB26zcar, I can see your not very hospitable. Obviously to avoid getting burned I searched the site and others Z sites for any info but didn't get anything I wanted. Later, Allen
  13. Anyone know anything about the E30 heads? I was wondering if anyone could give me some imfo on the specs of these heads, and if there would be any benefit in fitting one on a l24. Later, Allen
  14. was up guys, My car is in need of some minor rust repair soo I was thinking about pick up a mig welder. I found a craftsman thats 80amps and is gasless. Would this be good enough for fix the dog legs, and floor pan? I'm sure it is but just wanted to verify with you guys. Any tips would help. Later, Allen
  15. My friend just bought a 79' 280zx off of ebay the past week. At first the car would start just fine. But for the past few days the car wont start and we hear a clicking noise when he turns the key. Probably the starter... I'm just not sure how to check that. Anyway it's not the battery as I checked the voltage and thats fine... Any sugestions would help thx, Allen
  16. alabamaman882 not to be biased, but why do you wanna go 4 barrel? For a Z, SU's IMO there alot easiler to work on and more reliable. You could probably get a set for about the same price of a four barrel and its intake. Also a lot of guys here would agree that Su's perform better and can be tuned to perfection. If your interested check Z theraphy out. They offer complete rebuild kits and even a 2 hour video on everthing about the carbs. Away good luck on your project. ASA240Z aka Allen
  17. hella nice intake, great work! How much would one of those go for?
  18. nice movie, does anyone have the other movies? It would be a good idea if we posted these movies on limewire...
  19. check this link out, you might be able to get some of the info you want... http://forums.hybridz.org/showthread.php?t=97320&highlight=l28+table The search function is one of the best features on the site, try to look for the info you want, as it has probably been spoken of in the past... Any way, welcome to hybrid Z!! Allen
  20. I just finshed rebuilding my SU carbs and adding MSA headers. Well I think I have a couple of problems... first when I first started the car in ran, but I not sure if I running on all 6...I cant tell... I noticed the there seems to be more fuel in the front carb intake while a little less in the rear. So im wondered if the car is running on 3 cylinders. Also I noticed the first 3 exhuats and intake runners for the front car are noticibly hotter than the three on in the rear. Shouldn't the temp be close to the same on all 6 runners? In general the everying in for the first 3 cylinders are hotter than the last three. the second poblem is that I noticed that the headers seem to be smoking a little bit...Is this do to the paint burning? I bought the black coasted MSA headers So I want to ask you guys if these are signs of running on less that 6 cylinders. plz helps I afriad to drive the car knowing that it might be damaging the motor...
  21. Has anyone here used a corbeau belt retractor in a 72' 240z? I just bought a forza seat and I need to upgrade the belt. (when I bought my 240z it came with lap belts only)
  22. looks kinda ugly... makes me think about what will nissan do to the next gerneration Z...
  23. I call my Z, Bettie, after my favorite pin up model.
  24. Well I really didn't know where to post this, so sorry for the weird question...please admins don't delete my post... Being in school, I taking classes for my major in business, obviously one of my classes deals with business. For my class, I have to come up with a pretend business and write up a business plan explaining why I am doing this. My teacher allows any type of business, so I decided to make a car parts business specializing for Z cars. In order to come up with reasons as to why I am doing this for my project, my teacher requires that I come up statistical data about the market place and the demand of the products I am selling. I need to know what type of Z most people have, what are they most interested in "fixing up" and where are the majority of Z owners located. So in order to get this data I was wondering if you guys can help me out by stating what Z car you own, which state or country you live in, what motor you have and what you are most interested in improving in your car. Thx a lot for helping me out By the way, in my report I will not use any one's name or other privacy concerning things, all I need is stats in terms of percentages...
