Everything posted by CRAracer05
Thanks, I actually have a bunch of new photos to upload. I just got rid of my part car yesterday, but I kept everything off it besides the seats, and rear interior panels.Hopefully I will get them uploaded sometime this week.
Slow progress but here some pictures of what has been going on. Still lots of grinding to do but I,m trying to stay ositiove and just keep moving forward. Major battery box area rot that was patched with fiberglass by the previous owner Firewall repairs to follow. While is was cut open I coated the inside of frame with Eastwood Rust Converter and then Rust Encapsulater, and now waiting for everything to cure before I seal it back up. Start of of the repairs to the frame bracing area towards the front of the car. Hole patched with new metal. New braced burned in and lower cross-member skin removed. Inside of the radiator support was treated first with Eastwood Rust Converter then Rust Encapsulater.
Yeah I guess I never checked to see if they had side draft version.
- 4 replies
- dcoe
- carburetor
(and 1 more)
Tagged with:
Has anyone ever used the EMPI HPMX carburetors on a Datsun before? I tried to do some searching and couldn't find much of anything? http://vwcatalog.empius.com/vwcatalog/2014/60.html https://www.youtube.com/user/EMPIHPMX/feed They are mostly used on VW air cooled engines, but I don't see why you couldn't just bolt them right up. They have a few videos showing dyno results where they made a few more HP than there Weber equivalents.
- 4 replies
- dcoe
- carburetor
(and 1 more)
Tagged with:
WTB S30 Parts for Rebuild 5-speed, LSD, Flares, etc....
CRAracer05 replied to CRAracer05's topic in Parts Wanted
Bump.- 9 replies
- transsmission
- lsd
- (and 8 more)
Yes, all the flares are molded in. The front fenders are fiberglass with the flares molded onto the fenders. I was planning to remove the flares and list them on here, but I haven't made a donation yet to be able to post for sale listings.
I now have another complete 1976 280z that we can work out trades on if anyone needs something.- 9 replies
- transsmission
- lsd
- (and 8 more)
Well it finally got nice enough for me to go pick up my parts car. My father in-law was generous enough to give his 76 280z as that he has owned since 1978. We were going to fix it this year but when we jacked it up in storage we found that are absolutely no frame rails, or floor boards left. The inner fenders, rockers and quarters are all gone as well. We towed it to my house yesterday so I can take what I need from it. The main things I need right now are the hood and the roof/windshield channel.
PMs sent!- 9 replies
- transsmission
- lsd
- (and 8 more)
I am currently rebuilding/restoring a 1976 280z. I am located near Youngstown Ohio and would prefer large items to be within driving distance. Send me a message and we can discuss anything you may have. Items I'm looking for as follows: ZG flares Z432 rear spoiler or BRE Ground control coil-overs (280z) Camber Plates Toyota Front brakes vented or non-vented setups Rear Disc Conversion MSA 6-2 Headers (coated) MSA Twice pipes Fender Mirrors Rota RB stagger package wheels (black or gunmetal) Triple Carb setup (complete) Ignition Box Universal Fuse box and or Wiring Harness 5-Speed Transmission 280Z or ZX R200 LSD Flat top pistons (new not used) Cam (new not used)
- 9 replies
- transsmission
- lsd
- (and 8 more)
Appreciate your support, I am trying to get some practice in on these small areas before I get to hacking the entire floor out and installing the Zed/Bad Dog combo.
Well progress is slow between work and school, but I managed to make some more progress and get the driver's quarter panel patched. Keep in mind this is the first car I have done bodywork this extensive on, and I still to rebuild the inner portion as it was pretty rusty as well.
It has been a few weeks, but I made some more progress finally. I managed to get both of the rear quarter sections semi repaired with new sheet metal. I treated the insides of the quarter panels first with a coat of Eastwood's Rust Converter then two coats of Rust Encapsulater while the sections were cut out. I also tried to make the patches some what lower than the actual sheet metal in an attempt to allow for less filler when blending in the repairs. I just need to make the inside vertical sections next. Overall I feel confident this a much better repair than the solid chunk of Bondo I removed from both sides of the car that had been used to fix it previously.
Anyway here is a semi-update to my build plans so far: Body: MSA ZG Flares MSA Fairlady 432 spoiler Rear window louvers Headlight covers Suspension: Ground control coilovers Unsure on struts right now if any one has recommendations Camber plates (undecided on bolt-in or weld in) Car has an upgraded front sway bar already I will be reusing Wheels & Brakes: Silvermine Motors Stage 3 or 4 front brakes (still not sure which I want) Silvermine Motors Rear Disc brake conversion Rota RB Stagger package 17x8.5/9.5 (Black or Royal Gunmetal) Hydraulic hand/emergency brake Wilwood proportioning Valve (possible 15/16 master cylinder upgrade) Drivetrain: L28 4-speed Stock R200 open Diff MSA 6-3-2 coated headers MSA Twin Pipes Ebay intake with a real filter Interior: Painted no carpet, factory dash (possible aluminum door panels) Procar Drifter series seats (gauges undecided on Autometers or Speedhut) Things I'm considering right now are doing a mild build of the L28 if the budget allows. Plans would be cast flat top pistons, ported head, Isky .490 cam(not sure if factory fuel injection would like this). Also considered Carb swap. If I sell my 94 Eagle Talon Tsi AWD I might consider a RB25 swap with McKinney Motorsports swap parts instead. I really would like to make the car 5-speed if I keep the L28, but that is more money not required right now. I also want a better differential with shorter gears and lsd, but they are also big money. As I am getting another 76 280z parts car I may just weld one of the diffs up for now and see how I like it. I also want to replace the body harness with a universal Painless harness or just custom make one.
I haven't got much done recently besides I finally found sourced a clean hatch.
Little more progress over the holidays but nothing major yet. Rear end out and disassembled. Started replacing metal, my first attempt and I don't think its too bad. I under sized the patch to allow for minimal filler/blending. My wife started removing undercoating on the front of the car.
Worked on the car some more last night. I got the fuel cell and fuel pump removed. I also dropped the rear differential and suspension. I also started shaving the engine bay by removing now unused brackets. Here are some pictures of the dis-assembly progress so far.
Got my Zedd Findings floor pans and frame rails today. Debating if I should get bad dog rails now before my frame rails actually go bad and just reinforce this area ahead of time so I don't have to mess with them later.
Worked on the car some last night mainly took the exhaust and intake manifolds off to investigate the motor a little bit. The intake manifold and intake ports are slightly gasket matched but there doesn't appear to be any real port work done on the head. A look down the spark plug holes with a small LED light revealed a super fresh hone job but original dished pistons. Looking the oil fill cap the head looks brand new like it was just rebuilt. Appears to a stock cam based on wear pattern. I also got the transmission pulled and my wife pulled the seat and harnesses out. I also got some pictures of the fuel cell and cage.
Do you have any pictures of the whole car from different angles? Its hard to tell how the overall look is, but it does look intriguing from the shots you have posted. You caught my interest as I was going to be ordering ZG flares soon anyways.
Anyone have experience with DatsunZFiberglass.com
CRAracer05 replied to wayverippah's topic in Body Kits & Paint
I never received my hatch, and he just canceled the the order with no email or anything. I would be cautious. -
I just noticed today his Facebook page all of the comments got deleted for some reason........makes you wonder.
I'm looking for a decent condition new or used fiberglass hatch with or without glass (plexiglass). Also if anyone has a steel hatch in good shape near youngstown ohio i might be interested in that too.
My ultimate goal will be to hopefully get some track time and I am definately looking at upgrading the brakes. The AMC is my father in-laws Javelin AMX 401 4-speed project he has been working on. He is actually giving me his 76 280z as a parts car very soon. We lifted it up the other day and it needs full frame rails, floor pans, innner and outer rockers, quarters and hatch. The body is pretty much history besides the hood which I need for my car. He made the decision that it is far too much work to repair now. I'll have the entire spare drivetrain n42/n42 all original OEM plus 4-speed and rear diff. I don't have any really good interior pictures, I'll try to get loaded up by the weekend.
