renatodato
Everything posted by renatodato
L28 02 sensor reducer part? (please help!)
renatodato replied to PhilbertZ's topic in S130 Series - 280ZX
Wow, that is a little steep for the Cat. There is a little play on the exhaust end with a telescoping pipe but mine was so frozen i had to cut 1.25" from the cat and re-weld it. You can't cut the ends because of the flared connectors. If you must cut, cut between the flare and the cat itself, then, re-weld. Think of it this way, you'll never have to buy another cat again. Just keep the old one and swap it for the testing every two yrs. It takes about 20minutes to switch them. We get screwed in CA. Why is a cat legal in 49 states and not in one state? Absurd! This is one way to get back at the establishment. Good luck and keep us posted PS- I have an 81 280zx ET two seater Renatodato -
Hey PhilbrtZ, I still say no matter what you do in the engine bay, you will fail CA smog test if the cat is not converting the CO and HC to H2O. The emissions system is a mystery even to the inspectors. You need to go to the "referee" repair shop and they will actually test the car before final smogging it. Depending on the shop and the problem, it could cost you anywhere from 200-1000 dollars. A simple fix is about 200-300. A complicated fix, well.......My suggestion is to double check the timing, and the rpm. Did you change the PCV valve? EGR valve? Make sure your timing marks are right, then, use white out to paint the mark. Disconnect and plug the vacuum advance on the dizzy when checking the timing. Yes, CA has stricter emissions laws, that's why Autopartswarehouse only has one or two CA legal cats. I got mine for about 130 shipped. Also, check the harness to the O2 sensor. These wires tend to get corroded and brittle with age. Don't give up hope,bro. Pretty soon you'll be cruising in your ZX with a smile on your face like me. Renatodato -
Study the new water pump and locate the mounting bolts. When you're confident all mounting bolts are out, give it a confident and deliberate whack with a wooden stick as mentioned by Freakshow.
Don't forget the catalytic converter. If it's the original cat, most likely needs replacing. This could cause a failure in CA smog test no matter what you do to the rest of the car. What I did was to buy a CA legal cat from Autopartswarehouse.com for about 130. dollars. Since it's a bolt on, I switched the old one on for driving around, then, the new one gets bolted on when test time comes around. This way, the new cat will last indefinitely,lol. Also, would have been easier to get the female bolt at the junkyard and tossing the old one. Besides, it's free at the junkyard, hehehe. Just finished my strut/suspension rebuild job. I learned a lot tricks, so if you have any questions let me know. I get most of my parts online on Rockauto.com. Everything at Autozone and Kragen is twice as much. Renatodato South San Francisco -
81 280zx 5yrs in storage - running extremly rich!!! Help!!!
renatodato replied to bigseth's topic in S130 Series - 280ZX
Did you check the o2 sensor? Check the harness to the o2 sensors too. They get corroded and brittle after sitting for long periods of time. Get a stethoscope to listen to the fuel injectors. You should hear a 'tick, tick,tick' sound at each injector. If not, change them. -
There comes a time in a man's life when he has to break from his father's shadows. The father in the end, will respect the son more if he sticks with his guns and follows his convictions with confidence and independence. The knowledge you will have gained rebuilding your car is immeasurable. The satisfaction and joy you will experience is priceless.
Sears has a tool specially for rounded nuts, called "bolt out", costs about $20. Works great. Go to your local junkyard and get the OEM nut for free, lol.
Thought to be a leaking (NEW) windshield, but..
renatodato replied to LiveFree369's topic in S130 Series - 280ZX
Go to AutoZone or Kragen and get "window weld". It works better than silicone. I think it's urethane based. -
Hey Icewtr, I recommend you rebuild her. Take this opportunity to work closely with your son and teach him the virtues of defiance and hard work. Defiance, to those criminals of the world that they can't break your spirit to live. Hard work, to teach him that things are more appreciated when you earn it, not just given to you. Let him take the lead, so to speak, in the rebuild, even though you're holding his hand. Cars can be rebuilt, to its former glory; not so with the human body. Renatodato
Hey Wrez, Did you paint your rims black? What paint did you use? Looks sharp. I'm thinking of doing the same with mine. It's a pain trying to polish the Aluminum.
Hey C-Dawg, I'll see you 'round South City, homey. Nice Z. Don't mess with the car. It's fast enough as it is. You'll just get speeding tickets. Rey
Is there a consensus out there on removing the engine with or without the tranny? Some say it's easier to remove together, others say it's not. I plan on using the same tranny.
Check for rust issues at the roof junction of the windshield before installing another glass. Very common in these cars, but then again what do you expect from a 30 yr old car. I feel real lucky living in SF Bay Area with 18 Pick N Pulls, 2 Pick Ur Parts all within driving distance. And lots of Z's of all types.
Open the driver side door and pull on the weather stripping on the anterior pillar, exposing the phillips screws. Do the same for the passenger side. Once you've unscrewed them, wiggle them out. Be patient. Forget about saving the clips. They're plastic that's bonded to place with urethane. Cut them with a knife and snap them off. I took mine off without bending the trimmings. I have the same problem with rust. You can tack them in with adhesive during installation if you don't have new clips. I'm thinking of installing a used windshield from the junkyard myself. I'll post it if I do. AutoZone has the window weld and butyl rolls for installation. Harbor Freight tools has some neat windshield tools. Hope this helps you out.
Thanks, Warren. I disconnected the green/yellow lead and turned the sensor light off. I've always wondered what that funny looking fuse was.
Well, I tried splicing another wire harness I got from pick n pull and was careful not to have the shielding wire touch the main wire. Sensor light still on. I tried another harness , which I had laying around but no changes. I tried soldering and wire connectors with the same result. The O2 sensor is brand new and even switched the old sensor to no avail. Maybe Ruzn has a point about the electromagnetic effect. I'll try it tomorrow and see what happens. Question: Does the sensor light in the cluster necessarily mean the O2 sensor is not working when lit? The car runs fine and even passed smog in CA just last month. Warning lights in the cluster just bugs me. Rey
Thanks for the quick reply, guys. I'll be working on my resto this weekend since I don't have a mother.
The O2 sensor wire harness on my 280zx L28e is badly corroded and I need to splice another one that I got from the junkyard. The wire has an insulation wire that is wrapped around the main wire. What is the best way to splice these together? Can I just use a regular connector and forget about the insulation wire? Or do I need to solder them together? The O2 sensor warning light in the cluster is on. Any input is appreciated. Rey
Get a used ignition module from the junk yard and switch it with the existing one. If this solves the problem buy a new one.
