Everything posted by Jboogsthethug
From the album: Jboogsthethug's 1971 240z build
Question regarding wiring to steering wheel
Jboogsthethug replied to Jboogsthethug's topic in Ignition and Electrical
Thank you very much sir!! You're the man!- 6 replies
- 1
- steering wheel
- electrical
(and 4 more)
Tagged with:
Jboogsthethug replied to Jboogsthethug's topic in S30 Series - 240z, 260z, 280z
You are the man!! That is the exact shot I've been looking everywhere for! haha it looks like I'm removing the dash to figure out where all went wrong though. Unfortunate! I'll be a pro at it in no time! Thanks man!- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
I did a few days ago actually, It's all quiet on Z radio!- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
Actually, After reviewing these two diagrams I think the wire goes between the speedo and tach and then to the left of the steering wheel. It looks that way from both of these, if somebody can give me a thumbs up saying this is correct I'd be very appreciative, thanks!- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
just bumping the thread to see if anyone might be able to answer my question regarding the steering wheel wiring, I am at a loss.- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
1971 240z, sorry sir! I guess I should put that in my signature haha. that would be awesome, I would assume that it would be the same?- 6 replies
- steering wheel
- electrical
(and 4 more)
Tagged with:
Would someone be so kind as to look for me and tell me which side the wiring comes out of for the steering wheel, left side of it or right side of it, that would be super helpful. I'm having trouble getting the reach I need and I think I installed incorrectly.
- 6 replies
- steering wheel
- electrical
(and 4 more)
Tagged with:
couple of updates! I took off the exhaust manifold. That thing was perma stuck as it hadn't moved in years. I had to crowbar it off, I wasn't sure if there were bolts still stuck on it keeping it on but it was just super stuck. I also got all of the manifold bolts out without breaking any! I used the two nut method, tightened them on and used a hammer drill to back them off without snapping any. Stoked on that! I also got the driveline installed, easy enough! then I put in the pedals and steering wheel. Note: I would recommend this step before putting the dash back in, That was a pain, didn't quite think it through haha. cut off the old emissions piping to get to the nuts better. soaked these multiple times with magical PB Blaster and took a torque wrench to the bolts after a few days, Voila! Took a bit to loosen them up enough then finished taking them the rest of the way out with the hammer drill. Now to plug those bad boys up! then I took my time, cleaned up the ends of intake and exhaust manifold with a wire brush drill attachment, (The exhaust manifold to exhaust pipe side was interesting, the gasket had fused to the manifold over all the years so I had to scrape it off with a razor scraper first. then I also got new manifold bolts from Oreilly's (will switch those out later, but for anyone interested they're in a Ford exhaust manifold set, m8 1.25 both ends pretty sure.) as well as intake manifold bolts from Fastenal. New gasket from Zcardepot (I think, it's been a long time since I bought that) and tightened them by hand to around 22 lbs (I've read a few different actual specs, and I just guessed as I didn't have a 13mm in the 3/4 in size, which is what my torque wrench is. Probabaly will return to that one later). put on the carbs after a little refreshing and started re assembling all the pieces and taking off more emissions bologna! that's where I'm at now! Also, Big question! If anyone can look for me and tell me which side the wiring comes out of for the steering wheel, left side of it or right side of it, that would be super helpful. I'm having trouble getting the reach I need and I think I did something wrong haha- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
