Tarheelz
  • Location
    Carrboro NC
Recent Profile Visitors
Tarheelz's Achievements
Newbie
  • Reacting Well Rare
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Week One Done
Recent Badges
0
  1. For the 2+2 model? MSA will take yours and rebuilt and send it back to you. I am considering this as I drive a 75 2+2 and mine is making noise and not working right.
  2. This is great information! Can someone please point me to the Z car compression calculator mentioned above ?
  3. Hi did you figure out what the cause was for the oil caked spark plugs? Was it the piston rings? My Z has 5 out of 6 plugs soaked in oil and I've been avoiding pulling the whole motor...
  4. Hi, thank you for your reply! Yes, I have checked and rechecked the lash multiple times. Did a wet compression and went from 145-150ish to appx 160. Thoughts on that? Also, I found someone that has a p79 head on f54 block. Really good price what do you think about that combo? Or I could drop my rebuilt N42 head onto the f54 block...
  5. Hi Hybrid Z'ers so my engine block needs a complete rebuild as all of my plugs are pretty much soaked in oil. I don't have the ability to do anything like this, SO I'd like to hear best options for an engine and 5 speed swap?? I'm sure this is a repeated question but would love some input. Also, I would rather not spend more than $4 grand all in which cuts out some options I'm sure.
  6. Hi Hybrid Z'ers so my engine block needs a complete rebuild as all of my plugs are pretty much soaked in oil. I don't have the ability to do anything like this, SO I'd like to hear best options for an engine and 5 speed swap?? Would rather not spend more than $4 grand all in...
  7. Need to replace my intake/exhaust manifold gasket. Current one leaks at cylinders 5 and 6. Replaced two years ago with ceramic headers addition. Used MSA one. This is a tough job so want to get best quality one ! Thanks for any feedback.
  8. Hey thanks for the input! I will try that. Basically its just surface rust inside the shock tower and I can't get anything in it to sand it out... I'm concerned it will get worse so thinking about putting some POR in it? I could treat it with POR 3 step or maybe just hit it with some rustoleum spray... thoughts ?
  9. Good to know thank you for sharing! I have new rubber bushings on the TC rod already, so I will return these. I thought they were for the struts (even called 'strut rod bushings').
  10. Hi, since boarded in from the virus, one good result is I finally get to my do list on the 280Z! I took off the front strut towers to replace the struts and springs and all bushings. I had purchased the Energy front strut rod bushings but do NOT understand where these go from the repair manual diagram. They came in a pack of four see attached pic. Can easily see where the bump stop will go but not these... ? Also, second concern is the inside of the strut tower has quite a bit of RUST in it and do not know how to deal with that...? The rears are now done and they were totally clean with no rust inside... Any input would be most welcome! By the way, my car is a 75 280 2+2. Thanks!
  11. Removed the rail and tested injectors with a 9 volt battery and carb cleaner. 3 work, 2 clogged and 1 dead! Car has been running off 3 injectors! Ordering new ones and a new fuel rail and FPR right now ! Rock auto has new or rebuilt beck arnley N/a injectors anyone have any thoughts on those ?
  12. Interested in one of the L28 intakes. Also looking for a good 5 speed. Let me know b
