A to Z
Super Moderators
    44
Everything posted by A to Z
  1. July 2. I got the rest of the engine compartment painted today. When you are sanding around pieces, it takes a lot of time and effort. Then you take rope and pull them back from the area to paint. When dry, then you can clean up the stuff, release the rope and bolt it back down. At any rate, here are some pic of the engine compartment in fresh Datsun 904 Kilimanjaro White.. I got the engine painted and the engine bay painted....not too bad for having the car 11 days huh?
  2. I am using the factory exhaust manifold. It is a 3 into 2 setup. The exhaust bolts up to it as 2 pipes for about 1-2 foot, then collects into one. I'm going to paint it flat black with the high heat paint. I looked into headers but they said "for manual transmission only", so I decided I would keep the cool factory setup.
  3. ready to do the other side then bring the firewall together and then the radiator surround.
  4. After several days of work, I managed to get the passenger side engine compartment wall finished and painted. I used automotive paint in aerosol cans mixed in the factory 904 Datsun "Kilimanjaro white". Yep. Expensive, but I wanted the engine compartment car color as that's the way they came from the factory. At the battery box area, some scarring bled through the color. That is the All Metal I used. I was using 60 grit paper to form it. When it dries it is as hard as concrete, hence using 60 grit to form it. Tough work! At any rate, to hide the little bit of filler scars that are showing and make it look good, I will mask off a section under the battery and down a bit and spray on some bed liner. It would be cool if I can paint over the bedliner...if not, I can still make it look good. A Lot of work fixing this side......MANY years of being subjected to a leaky battery apparently. The other side is leaky brake master cylinder....:( Oh well, forward momentum continues. Here are some pics. First is in sealing primer, the rest in factory white with clear coats over it.
  5. scrub, scrub,scrub.......polish......wire wheel bit in drill...back and worth......whew!
  6. Thanks. I was thinking about using a different air cleaner setup, but I can just as easily keep the stocker. it's really in good shape. They are kind of hard to take off, not much room.
  7. I had other things to do today besides another 4-5 hours of Z car restoration, but I wanted to make some progress, and I REALLY wanted to get the block painting over and done with. I succeeded, I got out to the garage by midnight. I painted the passenger side at 1:30-1:45 a.m. took a shower and decided to check in here before hitting the rack. Here are some pics:
  8. I got the rust off. Once I paint it with the converter, it will "de-activate" the rust and convert it to Phosphate. I removed the rust, leaving the good metal still there, albeit a bit thinner than before. I have 4-5 small areas where the rust went all teh way through that I am patching, a tad bit of "all metal" filler to hide the scars, the pock marks where the rust almost went through, and it is good to go. The replacement battery tray I got is a stainless steel copy of the original from the Z depot. Instead of welding it in, I will bolt it in with stainless hardware.
  9. An up close look of the work needing to be done. I will cut out the holes and weld in new metal, the pock marked stuff survived the stab test with the screwdriver, so i will treat the rust with the conversion paint and keep on truckin'.
  10. battery box pic. yuck. 49 years of neglect. other side under the brake master cylinder is bad too
  11. Day 3. Started the day boxing up my SU carburetors and sent them off to a guy in California to professionally restore them. You can fight these things and they never really work well, sometimes just due to age and having a lot of slop in the parts, etc. When I get them back they will be BRAND NEW. Yes....terribly expensive! Then, I went around to the passenger side of the engine, and found yet more, dirty and tired looking stuff. I pulled the alternator, and the small capacitor on the outside fell off all rusty, un plugged it and this alternator is a small one 30-45 amps. So, I will replace with a modern 60 amp alternator that has the internal regulator instead of the old Hitachi regulator box on the inner fender. Next, I pulled the starter and alternator....not too old, good enough, but needs to be cleaned up. Went ahead and prepped the block for painting, it is ready now....just have to mask it off and spray. Now, the battery box was a bit of a mess. I had to drill and hammer and screwdriver, and Dremel cut the spot welded in tray to get to the floor underneath it. RUST. I did the screwdriver test and yep, I went through in a few places. BUT the majority was still strong enough to withstand stabs with a screwdriver. I wire brushed it up with the electric drill. I was going to get more aggressive with the grinding, but ten I realized I would only be making the metal thinner, so I stopped there. Now, I will spray the rust with the converter spray to turn it into phosphate and make the metal grey again. Then I will cut out the rusty holed areas and cut some metal and MIG weld it in. Then, I will use my all metal filler with a thin skin coat to cover all the pock marks in the sheet metal. Then I'll sand it and prime it and then Datsun white with a clear coat. I bought a stainless steel battery tray that is a replica of an original. Instead of welding it in, I will bolt it in, and leave it bare stainless steel. The other side? The master cylinder has leaked enough to make the other corner more work. 49 years of neglect, I am staying strong. Eventually, I will get to the work I like to do....I just have to get through the dirty yuck work. I AM losing a ton of weight over the last 3 days....very hot, and ending each day completely wet with sweat! I am getting old, this is my last go around with the old stuff, so this car is a keeper.
  12. roger that. Paint store in town sells SEM products. I have a BAD case of mildew. It all has to come out I'm afraid.
