A to Z
Super Moderators
    59
Everything posted by A to Z
  1. I used this for paint .... Krylon satin white, primer and paint in one. Does the job.
  2. Okay, a coat of primer/paint inside of both doors. You can't see what you are painting, so you spray, let it clean out, and use the phone to check. It'll do.
  3. Jury's out. I will let it cure and sand down and grind on it and see if it will work. I KNOW all-metal does, but I will try the Steelstick.
  4. Try the steel stick on the holes, and paint inside the doors with the rust preventer.
  5. exposing the holes, then taking a Dremel to them to open them up a tad to get rid of the rusty metal
  6. 11-22-2021 UPDATE: Gosh.....today was a good day on the Z car. Even though I got a late start, I feel like I got a lot done. I went ahead and cleaned out my doors, via screwdriver in the seam and vacuum, then wiped it out with alcohol wipes, then painted them with rust preventer and then finally, a coat of white. The pics are cool, as I am able to stick it in there, where you can't see....so when the "dust" clears, you take a pic, and see if what you have done is "good enough" or not. The driver's (left) door is clean as far as any rust holes, but the Right door was not. As I am out of all-metal right now, I decided to try some JB Weld steel stick. After it is hard, I will take a sander and grinder to it. If it falls out? GOOD. Better now then later. I went ahead and cleaned up and painted my windshield dash metal trim piece with satin black as well as it's mounting bolts. Also went ahead and measured & drilled and got the holes needed to mount the passenger mirror on, oh, and finally mounted my passneger fresh air pull knob to the dash underneath. My interior rear view mirror looked hammered to death....so I went ahead, sanded it up, went over it with steel wool to get it smooth, and painted satin black. The plastic part I wiped down real good with a rag and denatured alcohol. The mirrored face has a bit of patina around the edges. Oh well. I took A TON of pic's, and I will post them, with some commentary. If it's a tad redundant, sorry....as I have said before, I am keeping a record of all of this work. I hope you like. Any questions, please ask! Cheers! 11 43 Comments Like Comment
  7. here are the clips and pins I bought: 1970 - 1973 Door Panel Clips 36 Piece Kit for Nissan 240Z 2 Door Coupes | eBay
  8. 11-20-2021 UPDATE. Yesterday I pulled the door panels off, and got some pics of the insides. Pretty decent. I will need to repair the panels as some of the push pins have ripped out. I will use sheet metal bonded to the cardboard for reinforcement. Also painted and blacked out the center console......I can go over some of it later with a chrome paint pen. Sure shows how my dash is dry from the alcohol wipe down....time to armor all it.
  9. Well, to be fair, the interior panels are all new. The originals were so badly faded and crisp, that you couldn't remove them without them breaking apart and shattering. :( The door panels are original and the small side panels behind the seats are original. The vinyl over the struts was a faded pink before paint.
  10. 11-16-2021 UPDATE: Ok, well I managed to get some work done on my Z today. I went ahead and installed the door weather stripping and new kick panels. Installed the steering column trim after cleaning, and installed the cleaned up steering wheel and horn button. Next, I installed the seat belts, and I cannot figure out how the shoulder belts are supposed to hook on to the lap belts! After that, I went ahead and srubbed down some of the interior pieces real well with alcohol wipes, then I masked them off, and wiped them down real good with a rag and Denatured Alcohol. I went ahead and sprayed the faded areas with my SEM Color paint. Also began work on my center dash, vent face. Here are some pics: Precision door weatherstripping:
  11. I forgot to order LED for shifting light, but the upgrade is really making the old incandescent bright!
  12. 11-13-2021 update: I had a few hours today, so I went out to the garage, and finished isntalling my console, auto shifter, and finished the installation of the MSA parking light and interior dash lighting upgrade. It does definitely make the gauges brighter. The clock is a tad bit dimmer....i think when i had to push the green inserts in, the one in there might be partially blocking the light.....I think if I pull the glove box, I maybe able to stick a small screwdriver in the light hole in the back of the clock and bring the brightness up. Anyhow, I then cleaned up some more interior bits to include the steering wheel. I put it in the bathtub and used an old toothbrsuh and comet and boy you could see the dirty hand oils coming off of it. Then I dried it and took alcohol cleaning wipes and scrubbed....and yes even more dirty oils came off, but eventually it was coming clean. So, I will leave it as-is, but CLEAN. Here are a few pics:
  13. Z video 11-7-21.MOV short video on 11-7-2021. I miss you and love you, Dad.
  14. Safe to say, NOT FOR SALE. This is the car I should have bought 30+ years ago and kept. SO HAPPY I got one before they are all gone....or too expensive to get. I grew up with Datsuns, so it is natural to have one. I see a lot of views, but no comments. PLEASE say something, if it is negative, I can deal with it.
  15. 11-7-2021 UPDATE. Wasn't expecting to have much, if any time today, as I needed to do a front brake pad swap on my Daily Driver Civic, and I slept in from being beat up working on this old Z car darn near every day.....So, I rolled out the new carpet and put it in. The contrast really sets everything off! I also pulled the seats, and pulled the factory spacers that were on there....I gained an inch of lowering, which for me at 6'2 is a God-send. I decided not to fight my factory luggage straps....they were really worn and tattered, so they went to the dumpster. The carpet....needs time to stretch out and get rid of the wrinkles, but here are a few pics of it.....it just magnifies the need to color paint my strut covers. I can't tell you how good it feels to see it finally coming together. NOTHING on the interior has gone easy.....every single bit has been pure a$$ pain. I also took some pics of the car and garage environment.....the big boxes are installed, and it just feels good, at the 5 month point, to be seeing SOMETHING coming of all this work. So, why did I decide to put myself through all of this? Because the Z's that I was seeing for sale had something about them I didn't like and for the price, was unacceptable. 20+ grand and a flat black and not compeletely done engine compartment....that kind of thing. Z's are supposed to have a body colored engine compartment....in my humble opinion. AND....I wanted an S30 Z car. So, I bought this THINKING it would be a little work....but 49 years old means A LOT more work than expecting. It just "feels good" to see it coming about. Here are some pics fellas.
  16. 11-6-2021 UPDATE: Well, I decided to take an easy day...just go ahead and put the interior panels in, then get the carpet in and other things.....WRONG! If you have never done interior panels, let me tell you....they do NOT just "go right in"....maybe NISSAN factory pieces, but the aftermarket DO NOT. You need your Dremel tool handy, and be prepared to "adjust" grind a little here a little there, and oh yeah, the bolts don't line up! Infuriating! I managed to persevere. But It took the better part of the day, with the last pics being after sundown. You can defintely see that the shock tower upholstery is faded, but no fear, SEM color interior paint is here! I would recommend getting it anyway, as you MAY nick some pieces up during install (I did). I already have a can of the NAPA red SEM paint. Anhyhow, here are some pics. If some seem redundant, please understand these are pics I keep to record the work done.
