Flak280z
Flak280z last won the day on April 25 2024
Flak280z had the most liked content!
  • Location
    Pennsylvania
Recent Profile Visitors
3176 profile views
Flak280z's Achievements
Enthusiast
Enthusiast (6/14)
  • One Year In Rare
  • Collaborator Rare
  • Dedicated Rare
  • Reacting Well Rare
  • First Post Rare
Recent Badges
6
  1. Little update on this project. I daily drove this car to school all fall until I eventually blew the stock headgasket. I just needed to adjust the megasquirt pots to calibrate the ecu. Car sat most of the winter due to school work and 2 head bolts breaking when doing headgasket. Was easier to just pick up another n42 block, with good rings, hopefully no more oil burn. Looking forward to throwing in 440cc supra injectors with my 2mm kameari head gasket to turn the boost up. Hoping to just continue to clean up the bay this summer, and to start doing bodywork and rewrapping parts of the car.
  2. Have an n42 block without a crankcase fitting on it. What are the options to replace this besides dropping $100 on one on ebay? Using search, I can only find one picture where someone on here replaced it with an AN fitting, but no sizing. Is it hard to remove one from an old block?
  3. Hey guys, my turbo conversion is running well, no reliability issues. Still running 8psi of boost. My spool is at around 3500rpm with max boost at 4500. A little laggy, but I think that's because of my ebay turbo along with my turbo being mounted on the passenger side. Would someone mind looking at my tune, and making sure everything looks ok. I don't hear any pinging on 91 gas, but just want to make sure. My timing is a little aggressive. Stock l28e engine, n42 block and head, 8psi boost, 370cc injectors. 10_10_24 Tune.msq
  4. Hello all, just a reminder of my build, stock 78 280z 2.8 but with a turbo on passenger side. Running ms2, 370cc injectors, intercooled, 8psi, 3 core aluminum rad, stock clutch fan and shroud. Im looking at carbon fiber hoods and have come across Rs and Seibon. Have heard good things about Seibon, and mixed on Rs. Rs’ carbon hood is $1400 and has hood vents in stock locations. The Seibon hood can be had for $1000, but no vents. Is a vented hood needed? My temps are pretty good right now with the stock hood, in the humidity of this summer. If I went with my turbo exhaust is heat wrapped, but my header is not wrapped or coated. Should I spend the extra $400 to have venting, or can I get by without? I plan on p90 head swapping within a year to turn up the boast, might be better to vent.
  5. Took the car out two separate times today without changing anything and I had no issues whatsoever. I'm not sure if messing with the pots "fixed" the issue or what happened. I'm going to monitor it over the next few days. Other than the car burning oil, it pull hard and runs great. My tune is in a good spot, nice and smooth. I have a zx close ratio paired with the 3.54 stock rear diff which allows for the turbo to stay in boost longer (Also better mpg when my foot isn't in the floor). I am hitting my 8psi goal easily now, and my turbo wastegate and blow-off valve are working as intended. Attached are pics of the new piping. I used the old 2-1 y pipe that was previously under the pan, I just closed off one of the Y arms as seen in the pic. I also heat wrapped the pipes after these pics. The exhaust is much simpler now.
  6. I followed DIYAuto's instructions. You turn it counterclockwise 6 times to reset it and then turn it until it fixes the issue. Where do I probe the pot for voltage? I think the 280zx turbo dizzy is VR sensor.
  7. I fiddled with the R56 pot today. I can get up to about 3-3.5k rpms before it starts losing sync. Do I keep turning the pot to fix this? It seems very random. When I turn it too much, it starts losing sync at lower rpms or just loses the signal all together. Is there a method to it, or is it just resetting the pot, and fiddling with it until you get the full rpm range? I bought from godzilla race works, and apparently they already installed a pull up. Would it hurt to add another? What dizzy wire did you pull up? Appreciate the help.
  8. It’s the DIYAuto 24-2 Cas wheel for the l28et. I haven’t checked the pots, but have been reading about that on DIYAuto’s site. Godzilla raceworks installed a pull-up when I bought the ecu from them, but their ecu had other issues already, so I’m not counting out their faulty work. I will look into adjusting/testing the pots.
  9. I did pick up a square port exhaust and fabbed up a custom y-pipe. Both sides under the oil pan are v-banded and sealed nicely. I am making around 6psi atm. Now the bad part, after doing the exhaust, the sync loss issue is back, and very bad. I am getting a sync loss reason #2, and extremely frequently, as in every few seconds. This makes the car buck very violently, and sometime stalls when at idle and it drops all signal for a second. The car is undrivable. I attached a tooth log of the issue. As a refresher, I have the DIYAuto Cas wheel 24-2 2024-06-21_12.32.27.csv CurrentTune.msq
  10. Like I suspected, it is the exhaust not being completely closed causing boost issues. I reseated and clamped everything, and I can make around 3psi. Yes Brad, v-bands would be ideal. The issue is, there's no space to put v-bands how I have the exhaust now. I want the piece that runs under the oil to be completely removable, for removability and space reasons, just in case. I'm going to start looking for another set of cheap headers to chop up and combine to add a v-band, see picture for what I'm trying to do. On another note, I have a piece of "welders felt" between my turbo mount and the fender. It's not very thick, and does not seem like it would do much, but it is working pretty well to absorb and dissipate the heat. I can touch directly on the other side of the fender right after a 15 minute drive without it severely burning me. It's warm, but not burning. I'm going to throw a second piece between and pick up some ceramic washers like other suggested.
  11. Not too much to report at the moment. I’ve been battling electrical problems from the leftover stock harness, slowly replacing things. Did the ZCarDepot alternator upgrade because my stock wiring stopped charging due to corrosion. I can’t seem to make more than 1-2.5psi of boost. I’m going to retighten all of my intercooler piping and make sure my wastegate is working correctly. currently running an ebay special, 8 psi spring, no boost controller. I’m assuming it’s my pre turbo exhaust piping that’s leaking. I made the piping that runs under the oil pan removable, so there’s just exhaust band clamps connecting the two ends. It’s probably leaking around those, but I’m surprised I’m not making a little more. Attached is some test drives after rewriting my charge circuit, I love the way these cars sound. IMG_7704.mov IMG_7703.mov
  12. My oil pan gasket has started to leak a little bit. Last night, my oil dipstick also blew out. I check my pvc valve and hose. They both seemed ok, but I'm going to replace both regardless. Going to do a compression test ASAP, praying I don't have low compression after all of this. I really haven't even gone over 4psi boost.
  13. Alright, I've been going over the harness the past few days, refreshing the grounds, making sure connections are tight. I have also been rigorously tuning, both manually and using autotune. My fuel pump issue has mostly resolved itself! I believe it was a combination of the grounds and the base tune I got from the map sticky. Car cruises very nice with good AFR's. A bit rich, but ok for now. It still happens here and there, and throws a sync loss error of 2, so I will still research into that. This car is quick!!!! I can only build about 4psi of boost atm, I think I have an exhaust leak before the turbo. Either way, with my zx tranny and the matching 3.9 rear diff, this thing moves. It chirps tires off the rip and will even twist a little in 2nd or third if I don't miss my shifts lol. I'm thinking about throwing my stock 3.54 diff back in, it revs almost too fast. Took her for some overpriced burgers yesterday.
  14. Not a 12v supply. I mainly followed DIYAuto’s how to mega squirt post which said to use the same power source. Megasquirt’s db37 supplies the ground and signal wire for the dizzy
  15. Spoke too soon, the fuel pump issue is NOT fixed. It still cuts out randomly. Throwing a multimeter on the power wire, when it cuts, the voltage drops from 14 to 12, not sure if that drop is enough to cause the issue, or if that is a side effect of the issue. I redid my main megasquirt ground on the block, and also made sure my relay grounds were clean. Wiggling the distributor wires had no effect and did not cause the cut. Neither did wiggling where the dizzy is spliced into the megasquirt power wire. I'm going to monitor the main relay's voltage to see if that's cutting. In other news, I copied the ve table and afr table from the map pin with similar specs and the car runs and revs well, except when the car shuts down for a second.
