draztik280
Everything posted by draztik280
  1. I believe this is the one you are looking for? http://autopartswarehouse.com/details/QQNissanQQ280ZQQBoschQQWiper_BladeQQ19761978QQW0133-1648050.html Pin included. This is the one i got for my z
  2. Loving it. Clean Z. BTW who did the video? really nice video
  3. Im about to purchase a set of these RBs 17x9 front and 17x9.5 back. Are any of you guys running with these wheels with a tokico lowering springs and the tokico blue shocks? It seems everyone is running with coilovers. As soon as I get the wheels then I can start cutting the fenders. Thanks
  4. 16x8 also looks good, but I was planning on running flares with these boys.
  5. I am going to call the store today. They are located 3 miles from my house. I will try and ask if he would let me install these with the tires that i want and see if it would look good on the s30 before i buy them. hehe.
  6. I came across this website and saw this kind of wheel. does anyone have these set of wheels in their s30? http://www.nlmotoring.com/XXR-527-Wheels-17x9-75-Chromium-Black-p/52779082n.htm
  7. I have the same problem in my 280z. I replaced the Ignition Control Module and the problem went away.
  8. Thanks for the Info. I might go and check it out after the Auto Show which is in LA.
  9. I need help regarding this problem that I have on my car. Car is currrently stock. This morning when I start the car, it started fine, until the car warms up and when I drove it, the car suddenly stalled. I was thinking that the fuel filter is clogged/ dirty. So I replaced it and still doing the same thing. So then I inserted a fuel pressure gauge. When running, the reading is around 34 psi. In the OFF position, the reading is 19 psi. I checked the TPS and it seems ok. so as the AFM it opens freely. What seems to be the problem? Does the Fuel Pressure Regulator gives this problem? Car shuts off if you push the pedal and sometimes turns off when on idle. I attached a video so it is easier for you guys to tell what seems to be the culprit. Thanks so much in advance. http://www.youtube.com/watch?v=0FS4E2BOOXw&feature=player_embedded
  10. I am getting 16x8 xxr 513's on my z w/ tokico springs and struts. but clueless on what the max tire size i could go.
  11. do you have the pics of the rails? I am thinking of getting the eclipse seats or the miata.
  12. I will keep an eye out here in Northridge.
  13. I also want to know about this. I am about to purchase a set of wheels and tires for my 77 with 16x9 w/ tokico hp and springs. Nice car btw.
  14. thanks for the info about the mc-master weatherstrip. I may also order these today since I cant find any Sportage in the JY in my area.
  15. I have a working Quartz clock in my 280z. The only problems is that the time is not accurate. It falls behind all the time. I set the clock at 5:30, 5 mins later, the clock only had moved 3 mins. Is there anyway that I could fix this problem? Thanks
  16. I don't know if anyone have these in their Z.
  17. Does anyone have these thing installed in their Z? Any experiences? Good or Bad? Seems like a good device, but I want to know if anyone here have this thing in their car. I've seen Muscle cars with this thing installed. Here is the link http://www.nohotwire.com/
  18. Thanks. Im fixing it right now. Finally got it to work. I did replace the fuel filter, but it was still the same. I then tried and open the Throttle Position Sensor. I sprayed some WD40 and let it dry for an hour. Now, the hesitation was gone. Thanks everyone for the help. finally get to drive the Z again here in sunny CA.
  19. I will check this tps problem? should I just replace a new one then?
  20. bought new fuel filter and i'll see from there. Thanks.
  21. I need help regarding about my 280z. The car starts fine and idles great, but when I start to accelerate above 2000 rpm, the engine started to jerk. It feels like its cutting fuel. I checked the distributor cap, its fine no moisture. all the spark plugs are hooked up fine. I can't figure out what's the problem. Probably bad fuel filter? or condenser? I attached a video below. Thanks. http://www.youtube.com/watch?v=0O301Dl6WwA
  22. Really love the set up of your car. I just wanna know what kind of strut/springs you have installed in your car and how low the drop of the springs?
  23. I did use the duplicolor vinyl trim paint on my interior. painted everything from tan to black. including door panels. does its job. i did put around 3 layers of coat so it wont flake.
  24. I bought these door locks a week ago. I recieved it today and removed the original door lock and realized that they are not the same. The original door lock, has an L shape compare to this new one. Is there any thread of how to modify this lock? Thanks http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260467938017&viewitem=&_trkparms=algo%3DLVI%26its%3DI%26otn%3D1&category=33642 Original Lock http://cgi.ebay.com/ebaymotors/Datsun-240z-260z-280z-Door-Locks-LF-RT-NICE_W0QQitemZ370250990608QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item5634adc410&_trksid=p4506.c0.m245
