Thanks for the info. There was some play in the linkage which I have now fixed, it now goes to WOT with the pedel after playing around with it, plug gap now set to 0.040, and the jets are actually screwed in place. It'll be a few days before I can pull it out of the gargage to start it but I'll post the progress.
My regulator only lowers it to about 4.5 PSI - I found one just like it in the Summit catalog and it's minimum setting is 4.5 PSI so I guess I'll have to find a lower pressure regulator.
Jets are as follows:
Top end of the long jet - 200
Bottom end of the long jet - 150
Jet next to the long one - 545 (not sure as they were hard to read)
Jet out by itself under a small plug - 40
What I assume is the idle mixture screw is two full turns out
Engine is a 2.8 liter w/ mild cam, 6-2-1 header, tripple 44 mikuni's (I could not find any model # on the carbs but they measured 44 mm), MSD 6AL, not sure what else but manifolds are port matched to carbs - manifold has F.E.T marked on it if that means anything. Do these jets sound reasonable for this set-up?
Thanks again.
Cameron
