the computer may have been fine but if your injector leads are toast it doesn't matter. changing the connections between the computer and the injectors is a cheap theory to test.
As far as timing goes if the distributor was removed one of the bright-eyed mechanics might not have marked the location of the distributor when he put it back. If that is the case you may not be able to adjusts back to the correct timing with the cog it's on (Although you will be annoyingly close) An easy, ham fisted way, to test this is by having someone crank the car and just turning the distributor and gauging how close the engine is to starting. if one extreme of rotation give more activity then move then remove the distributor and move it separate from the rest of the engine over one cog, rinse and repeat. If you have eliminated all systems except the ignition this is a good way to find an adjustable range. also check to make sure that all the ignition leads are in the proper order. I realize my last to theories rely heavily on mechanic stupidity but If you think about it they do this stuff all day and could not care less if it breaks so they are bound to make some mistakes. once a competent mechanic forgot to fully install the plugs. any way good luck
