pjo046
Everything posted by pjo046
  1. Hey, that cold air feed looked brilliant! Thanks! Think I'll try to do the same thing!!!
  2. pjo046
    JSK fuelrail
    From the album: My 240Z with 280ZXT engine project
    Here is the fuel rail I have bought from JSK
  3. pjo046
    Throttlebody spacer
    Here is the throttlebody spacer I have bought from JSK
  4. pjo046
    Adapter for the rims
    Here is the adapter I have bought for the rims, since they are 60 offset
  5. From the album: My 240Z with 280ZXT engine project
    Here is the throttlebody I have bought from surfcolorado at zcar.com
  6. From the album: My 240Z with 280ZXT engine project
    This is the shifter I have bought of ebay for the T5. (Which I haven't gotten hold of yet)
  7. pjo046
    17X7 rims
    Here are my new Konig 17x/7" rims for the 240Z. Will fit 215/40's on them
  8. Hi! I will have a 1981 280ZXT engine with a t3/T04E hybrid with stage 5 exhaust wheel, 50 trim, 0.63A/R turbine and .50A/R compressor. I have a 26x7x3" spearco intercooler(core size) with 3" outlets, both on the same side. It's like the one on the photo below, exept the the outlets are facing the same way. http://album.hybridz.org/showphoto.php?photo=791&sort=1&cat=500&page=1 This means both the intercooler tubes will go through the radiator support on the same side. Also, the TB is 60mm, which is about 2.25" right? And I think the outlet on the hybrid turbo is 2"? Definately not bigger than 2.25". So I was originally thinking about 2.5" plumbing, but is there any point in doing that since the TB and the outlet from the turbo is smaller? Also, if I use 2.25" plumbing it will be easier to fit and to get it through the radiator support. And I'll avoid pressure drop due to too large tubes. Or? Please give me some input on this. And I've heard the extra money for aluminium tubing isn't worth it? Stick with stainless steel? Last question here. Since both pipes to the intercooler will go through the same side there won't be room for a cold air intake. Would you route a 3" pipe through on the other side?(let it go straight out from the turbo, bend 90 degrees and go on the inside of the radiator, then bend 90 degrees and go out through the radiator support on the other side and there I'd have a huge conical filter? (Would of course use an electric radiator fan, otherwise this wouldn't work) But will the restriction of this tubing be worth it since I get colder air in, or should I just attach a filter directly to the turbo, thus getting more air in easily, but also it'd be much hotter air.. ??
  9. Sure! Sorry, didn't think of that! Didn't mean to offend anyone, just thought the picture was nice.
  10. pjo046
    under
    From the album: My 260Z 2+2 turbo
