Alright, I have searched this issue and found good information pertaining to the TB whistling problem, but I do not think that is my issue. I believe the whistle is coming for somewhere else around the intake system. Here's my problem:
On a cold engine, there will be no whistle what so ever. It is only until the engine warms up a little that it spontaneously just starts to whistle very loudly. This whistling only happens at idle or very little throttle. The whistle is so loud that you can hear it from about a block away, and my car is also running straight pipes. So you kind of get the idea of how embarrassing it is to drive around with this problem.
Another thing is that once I turn the engine off, and the belts stop, the whistle will continue for about a second, they very vacuum-like, die out and raise in pitch over the next 2 seconds.
I thought it was my TB, so I took off my intake elbow and while the car was running I put my fingers around the edges of the blade, and tried closing off all the separate holes inside where air was being sucked in and none of this effected the whistle in any way (except making the car slightly die out).
I listened as best I could, but I could not locate exactly where its coming from... at times its sounds like in the front of the engine, and other times seems like its coming from the back of the engine. Its a newly rebuilt LS1 and I only have about 200 miles on it. Its been doing this ever since I got it running properly.
I just can't figure out what would cause the whistle only once at operating temperature and only when its at idle, or barely open throttle.
Please guys, any help is very much appreciated.
Any suggestions?
Thanks,
John
