Hey all, unfortunately this is my first post.
A little background on my car, it is an 82, with an 81 L28ET swap:
I completed the Z31 ECU swap 2 weeks ago according to the writeup by Ashfin. ECU is a Remanned one from an 85 Z31T. The car idled great till it warmed up, and then it started sputtering HARD. From total cold, to the heavy sputtering, its only a couple minutes.
Blipping the throttle will made it stumble and then go back to sputtering, holding the throttle down at all will kill it. It idles less than 500 rpm, barely.
It ran perfectly with the 81 ECCS before the swap.
Things I have done and checked include:
New Nissan CHTS, checked harness continuity, both component and harness pass.
New Nissan o2 sensor for an 81 L28ET, verified that it was giving voltage while the car was on, gave a steady .3ish volts.
TPS is from an 83 NA if it matters. Has continuity at throttle closed, no continuity after slightly open. Checked harness.
Tried 4 different MAFs, tested EVERY ONE against FSM tests, all check out. Current one on car is from a known well running car, along with the ECU.
I had to have rechecked all the Z31 swap wiring 10+ times, and I see no error.
Fuel pressure stays steady and never drops once warmed up (it actually goes up, due to bad vacuum from horrible idle)
Unplugging the CHTS causes the idle to go smooth out and run fairly well. Car will not start without CHTS plugged in (as its supposed to, IIRC).
CAS disk is in the correct oreintation, and is almost mirror clean with no debris or scratches. Tried 2 different CAS units, one from a perfectly running Z31T, and one from the 83 dizzy I am using.
Timing is set at 20 BTDC.
Checked harness grounds, at the grounds, and at the ECU plugs.
Air regulator is working properly, and shuts once warmed up, it is also a new Nissan unit.
Coil and Power transistor are from an 87 Z31.
The only real running code the car has is a code 11, CAS, not really sure what to make of it, as the car ran perfectly fine before the swap. I don't have another ECU to try =/
I have been battling this thing for 2 weeks now, and I am getting very close to just breaking down and swapping the old 81 flappy box and ECU back.
My problem is frighteningly similar to this Zcar.com post, on this guys 85 Turbo Z. http://www.zcar.com/forums/read/2/2022915/2022925#msg-2022925 but it was never resolved that I have seen.
If anyone can provide any help or insight, maybe something I might have missed, I will love you forever.
