AnTmanS130T
Everything posted by AnTmanS130T
I've been running the same World Class T-5 for 2.5 years now. Making 300whp on a dynojet and 255whp on a dynodynamics loaded dyno. When I first put the transmission in I ran ATF for a little and it was always really rough to shift ( I guess the bad synchros and such a thin fluid) I tried Mobil 1 synthetic and since then it has been a lot better.
This actually happens to me as well. I can only run so low of a boost no matter what conditions ... I usually run 14 psi (T3/To4e 57 trim) daily on the road but more when someone wants to run 18-20 psi on 100 octane. (Safe for now, untuned) The problem is the internal wastegate hole is too small for all the gases. Even with my actuator disconnected with the flapper moving freely... it will still go way above 10 psi. It came to the point where it drove me crazy because I tried everything ... MBC and EBC.. They will both hold but def can't run low boost pressures. I run the Greddy Profec B SpecII now, but still only able to run so low of boost. I don't really care anymore. If you want to fix the problem.. port the hole as much as you can so the flapper still covers the hole.
Detonation will kill forged pistons or cast aluminum ones... Yes I understand it will take a little more but that's a little more money. As far as the motor goes.. the crank and rods are forged from factory. The stock pistons can easily handle 15 psi without any detonation. Goodluck
everyone that has built a custom intake for the L6
AnTmanS130T replied to turbobluestreak's topic in Nissan L6 Forum
How much do you think that manifold will cost Cody? Let me know, I may be interested. -
I have had this problem for a long time, talk about frustrating. I notice with the both lines used, the valve leaks and causes the car to bog down as the rpm's go up. Right now I have the type- s on the car .. for about 15psi .. I have the valve pretty tight but not all the way. This allows lower boost to vent and allows the valve to hold shut and not blow open at the higher boost..like it has a billion times. It's just all about getting the tension right for a certain amount of boost. It's a real pain in the *** and real annoying.
L6 Smoking from around turbo after boost
AnTmanS130T replied to george.bryant's topic in Nissan L6 Forum
I was meaning to check all coolant hoses, not the headgasket. That is pretty obvious it is blown most of the time.. Oil in the radiator, car is overheating, possibly even smoking a bit. Retap the manifold, I've had the threads strip themselves before. As far as the waterpump, there is a weap hole on it that usually starts dripping when it is going bad. -
Make sure you check all your fuel lines, turbo oil feed line, and make sure you don't have a coolant leak. You may have an exhaust manifold leak, check the torque on all bolts. (Usually if you have an exhaust manifold leak you will hear a loud sharp ticking like an injector) Keep an eye on your oil levels, make sure you are not blowing it out of the back or your turbo is going bad and causing you to burn oil. That's about all I can think of with little detail given. Goodluck -
http://www.myspace.com/hallucinationed1 Just figured I would throw mine up.
I've tested my manual boost controller and it was dead on. This profec is so damn hard to nail on dead boost for all the options. At least I think so..
Any ideas on how to manage boost creep?
AnTmanS130T replied to Thumper's topic in Turbo / Supercharger
You could always get rid of the profec b boost controller and run a bleeder valve. I run the profec and I have creep on my setup similar to yours. -
Anyone?
Does anyone run one on their l28et? If you do.. please share your settings. I have been messing with mine for months and havn't exactly mastered one. I am still running the stock actuator on a t3/t4 57 trim .. no matter what I can't seem to get my boost set anywhere dead on. I am sure other people could use the settings as a general area. It's hard to set the gain percentage with a start boost that doest spike etc etc. Thanks, Ant.
I was looking into doing an audible detonation setup with the headunit through AUX input. Just out of curiousity, what type of detonation setup do you use?
Good question. I myself am curious how everyone has their nitrous setup with the l28et. Let me know how the setup works out for you, I am really itching to spray mine as well. I don't hear of many spraying our motors if rarely ever.
I ran 10-30 non sythetic for a few thousand .. switched to 15-50 to 20-50 for summer. Mobile 1 synthetic
Tokico Shocks / Springs
AnTmanS130T replied to AnTmanS130T's topic in Brakes, Wheels, Suspension and Chassis
I called MSA, they said that the boots come with the struts, only the kyb's and tokico hp's. The Illumina's can be purchased seperatly. Thanks -
I am planning to get the Tokico Springs with the Tokico blue shocks for my turbo 280. I figured I mide as well change the bushings so the urethane msa bushing kit will be part of this upgrade as well. The strut boots on the car are pretty old and worn out. I cannot find them on MSA's website and Victoria British only lists the front and not rear. Anyone have any info or know a place where this can be purchased?
Can someone describe what compressor surge sounds like?
AnTmanS130T replied to a topic in Turbo / Supercharger
Should I use a T off the same source or use a seperate source of vaccum for the other port? Thanks, - Ant -
It's a greddy type-s. The bottom port is not being used.. I was never exactly sure what it was used for? Is there something that can be done or why would the b.o.v be doing this? -
This being said, I have had a surge problem while I was on the dyno.. I thought it was my blow off valve leaking or something else. The car has an ocassional surge problem, sometimes up top of 4th gear ..I do notice the needle will fluctuate on the gauge sometimes. I was thinking this was due to location on the intake manifold, near a runner. Hmm I wish I could figure out what is causing this. I was thinking about reversing the vacum line on the b.o.v to keep it shut and floor the car to see if it still surges, atleast that would eliminate the b.o.v having a problem. On the dyno it seemed as if the car would jerk a little while surging. Any input ?? -
Turbo Exhuast Valves and valve stem seals
AnTmanS130T replied to HadesOmega's topic in Nissan L6 Forum
http://www.importperformanceparts.net/imports/importsnissan.html This place seems to have a lot of things. Hope this helps. -
Just out of curiousity, why did you use 240 rods instead of just the 280 rods ( being that they are forged) and where did you purchase the pistons from?
I run a 89turbo reprogrammable ecu on the 280 and I have been wanting to add some type of knock detection system. I know casper electronics has a few for grandnationals which would work and MSD has a knock detection system, I am curious if anyone runs one or has experience with them. I would use the stock detonation circuitry but that cannot be used with my car. I plan to increase the boost pretty high and have been debating whether I want to build my own methanol injection kit or go with a few options ( money depending ) Either way listening to detonation isn't good enough and will not always be heard so I would like to do things the right way. I would need to use an existing threaded port on the block, that I have not seen or figured out yet.
Garrett, if you could answer the few things I asked on page 1, I would greatly appreciate it.
You metioned the car being a 3 liter.. how much did you bore the block and where did you get the pistons from? Also what compression ratio are you running? I assume stock forged crank and rods ..
