DavyZ
Super Moderators
    4
Everything posted by DavyZ
  1. One thing to add to this good discussion: The EFI atomizes fuel better than a carb, but is probably more of a chore to install and is more expensive--at least from my research. With a single-plane intake, the EFI may counter(?) some of the inherent bog or delay one may experience with a single-plane intake? To just touch on what WebWalker asked about, perhaps something (hit or miss here) that contributed to the uneven mix at low rpm: way lumpy cam (not the best match?) and maybe the carb you were running (too much carb, jets not right, etc). Just some things I'm thinking about since I was not there. I'm sticking with my Weiand Stealth manifold which is supposed to act like both a single and dual plane intake. It has a split personality! David By the way IMO this discussion has been really excellent and thought provoking. Everyone has put in a great amount of thought and expertese. Very enjoyable!
  2. Anthony (Triple threat311), Are you getting the idea of which swap that we think is the best (overall)? I'm not trying to be sarcastic or anthing like that, but those who picked the JTR kit (whether they fabbed it themselves or not) are very opinionated that it's the way to go... Just food for thought. Maybe some of the Scarab guys can kick in a few comments. I know there are at least a couple of guys who enjoy those kits as well. Hope this helps you, Anthony. David
  3. If the trans is a "good" one, you could just get higher gears (like Evan said) and you'd be there. No, that was not a dumb question. You might as well post anything on your mind! David
  4. Sometimes I wonder where we would be without guys like Tim & Ross. At least they read the archives! With respect to the road issue. Here in Northern CA, the roads are pretty bad as well. Taxes from gasoline are supposed to be paying for roads, but it all is a crock of you-know-what. Finally they paved the main boulevard where I live! You couldn't get the rear end to hook right with all those pot holes The worst freeway bar far is the Nimitz (I-880). It's never finished and they let it get really bad before they start repaving it...I guess a few lawsuits against the city in the works gets someone to DO something about it. David
  5. Fraga, are you CA? If not, check to see if you can get away with getting an exhaust system that has no catalytic converter. Don't worry about "hurting" the environment because that cat didn't work for more than 5 years anyway after the car was purchased! Many of today's cars give longer warranties on smog related parts, but not back then... David
  6. It should say "CA emission compliant" somewhere under the hood. 95% (not 100%)chance it was a CA car.
  7. Cool! I have been looking for a decent deal on used aluminum heads, but I have to be very patient! Glad to hear you're happy with the heads; hope they work out really well with your application. David
  8. Mark, the dual-plane intakes are more streetable not because of distribution per se, but because the air/fuel mixture has a higher velocity at lower rpms. Thus dual-plane intakes have better low end torque and off the line performance. A single-plane intake is better at high rpm. Our cars are relatively light weight for the torque, so is a dual-plane intake really necessary. I have one, and my motor is cammed and capable of only 0-5500 rpm max. This favors the dual-plane intake, period. My next motor will be a destroked 400sbc to 377 or even 350 ci. That will be a revvvver and I'm looking to spin upwards of 6500rpm. In that case, a single-plane intake would be best. Plus the cam selection will reflect the rpm range I will run in. Make sense? David
  9. Anthony, first off I would like to welcome you to the best forum on the web! If you have done a bit of reading using the "search" function, you've found that there are varying opinions on conversions. It sounds like you stumbled Lonehdrider's thread where Kevin, Owen, Richard, Len, Pete, and myself were "discussing" the JTR manual. The summation of that thread is that Mike Knell's manual does need an update (he knows it because I spoke with him last week) but it is still the best manual out there, and NONE of us were arguing over whether his conversion was the way to go or not. IT IS. Anthony, you ask "which is better?" Do you want the best handling? If you do, go JTR. Many of the guys, if not most of the guys in this forum have the JTR setup. Some of them have had both like Long (Dankinzle) prefer the JTR set up overall. Find his post, log on to his site and readup on why he likes the JTR version best. After researching independent of this site, I found the JTR set up to be the best so I went with it. The engine is set back closer to the firewall and is better for weight distribution and handling. As far as having only "general" information in the JTR manual, borrow one or take the chance and buy one before you make the $3000+ decision. Mike Knell wrote the manual and stated that you should have a Chevrolet service manual and a Datsun manual--logic dictates that for any conversion (including John's Cars for that matter) you should have all of the information you could need or would need to make it go smoothly. The JTR manual gives much information including other things like brake upgrades, etc. Does John's Cars do this? I don't think they do. The choice is yours and it's a good thing you posted--so you can get everyone's opinions on why they did what they did. You have my biased $.02 anyway! Good luck! David [ May 13, 2001: Message edited by: DavyZ ]
  10. I have not heard too many bad things about MSD boxes or their distributors either. The GM HEI is a good distributor and has a coil inside. Their effective voltage is good up to about 4000rpm or so (depends on who you read and who you believe) and after that the voltage drops off considerably. What rpm range do you run? If you find yourself bumping into 6000rpm often, upgrade an HEI to a hotter coil and/or ignition unit. Would you believe MSD makes the best module for the HEI according to David Vizard? Accel also makes a unit that is pretty good and cheaper too. If you are really not satisfied with your MSD stuff email me... David
  11. I tell you that the VW Scirocco single wiper is way cheaper and more plentiful at the wrecking yard... Come to think of it, there are other cars with single wipers too. I'm thinking I saw an Alfa Romeo(?) with a single assembly. I believe it was Italian...
  12. Be patient, Grasshopper, and your answer will come in time...
  13. Way to go Scottie! I hope the fix isn't going to be too expensive for you. It's kinda like, "yeah, I found out that both my aluminum heads I bought are cracked, that would explain the problem." It pains me to hear stuff like that...all the $$$($!). All the best, David
  14. I never used glasspacks before and I'm sold on the "turbo" mufflers anyway. Brand is not that big of a deal--I like Dynomax personally, but others like Flowmasters which are a different animal altogether. I've not been a fan of Supertrapps because tests have shown that they put out more noise per hp gained then "conventional" performance mufflers. They are tunable, which most others are not.
  15. I agree on the Turbo muffler--they do really well on the Dastsuns in terms of sound. If you are really sold on glasspacks, MSA sells a pretty good DIY kit. Price is about $169. This is for a dual-exhaust system.
  16. It really bothers me that the car will still not pass emissions. There must be something really wrong somewhere to have that happen. This forum is very good at making emissions but not very good at eliminating them?? Sorry to bail on you, but I'm out of ideas. There has to be something very wrong somewhere, though, for that car not to pass. I'm very puzzled. Sorry, Bub. David
  17. Dan, if you've owned the Jacob's stuff since new, that would be my choice. I have never heard of Jacob's stuff being the cause of such a problem; that sounds too strange and I don't think the MSD 6AL will solve your problem; but, if you bought it used from a flea market, then who knows? I'm assuming the fuel pressure (3psi) is actually line pressure, not pump pressure? If it's line pressure, kicking it up a notch to 4psi or even 5psi. Your radiator and cooling system is definitely a problem. If the car can't get through traffic w/o heating up like that, then there's your menace. What radiator are you running? Are you using a fan shroud? What kind/brand of fan do you have? Shoot, when was the last time you flushed the system? Are you using straight coolant or a 50/50 mixture? Water cools better than coolant alone. I would not yank the Jacobs stuff yet, without addressing the cooliing system on your car FIRST. Hope this helps! David
  18. I'm putting my Q45 in the garage about now...
  19. The Z's have a sultry-sounding woman saying something like, "Your door is open..." "Your handbrake is engaged" "Your engine is falling apart" Stuff like that. To picture it, think of a very sultry voice when repeating the phrases. It was a hoot back in the late 70's and early 80's hearing this stuff. Kinda neat actually.
  20. Randy, you know I'll be calling you when I get these excess cars of mine sold. Hopefully as soon as next month! David PS Only 240Zs will be allowed in my garage! This 260Z is going bye bye...
  21. Bill, it's gonna be higher in a short while. Looks like a rust free car just waiting for a V8 conversion. Room enough for the whole family too! David
  22. I have also broken easyouts before--no fun, no fun. I have been blessed by not having a hard time removing the easyout!
  23. Good to hear; there's hope for me yet! David
  24. Paul, don't lament the fact you might have paid too much for the Buick. I'm in the car business and I can tell you to throw the Kelly Blue Book out the window when it comes to a nice, rare car in exceptionally good condition. There is a specialty auto place down the street from me and they have a GN of similar vintage, but looks like crap even after detailing. They are asking $10K for the car!!! What's a little more for an unmolested car with much lower miles and in great shape? It's worth it. So, suck in your stomach, work with what you've got, and blow everyone away! No problem... David [ May 09, 2001: Message edited by: DavyZ ]
  25. John, I hope someone else chimes in here, because it may be several days until I can even look at my car...Sorry.
