ZXRockie
About ZXRockie
  • Birthday 03/20/1982
  • Gender
    Not Telling
  • Location
    Travis Afb
ZXRockie's Achievements
Newbie
10
  1. http://rbforums.org/5.html
    I need your email bro... txt me with it
    Read more
  2. thanks brother, I'm in the search of a plate that allow the stock oil presure sensor, but not luck...
  3. Nice work brotha! I notice that you are using an oil relocation plate, do you have the part number or model by any chance?
  4. The gasket was a bid humid in that section, between #2 and the passenger side water gallery, compared to the rest of the gaskets and that was my theory. the rubber seals were gone and toasted. tomorrow is the day, i let you know how all went... thank you for your input.
  5. sorry to burst your bubble, but it does. the front section ins like a bridge between both heads. I had replace the lower manifold seal, so wish me luck.
  6. I found deposit of coolant right above my #2 cylinder intake valves. I've never seen anything like it, but I strongly believe it has to do with the lower intake manifold gaskets. what really causes this problem? because of it the #2 injector keep going bad and the car runs like it wasn't meant to. Please help me to determine the cause of this disaster, can't stand running in 5 cylinders and buying injectors is not fun.
  7. what about MS, what did you used? which model?
  8. I have and they do not keep the heater.
  9. I know many of you have done the 240SX S13 dash into your Z. Does any one kept the heater or it is almost impossible. I'm in the middle of the proccess and I would like to see some examples, tips, recomendations or ideas. any input will help. Thank you
  10. who can do the wiring around northern california? what shop do you guys recomend? I call Z car garage and they like doing the whole swap, I'm good with the mechanics I just like the electric to be done by the professionals.
  11. Does anybody has pictures of the water lines in the RB25det after the greddy manifold is installed. that's what i need to see.
  12. I thought you went to Venus auto in Sac. I'm half hour away from sac and I'm building a RB z.
  13. I would loike some pics... Stealth-Z whre did you get you Cluster from?
  14. My project has the z31 5 lug and the Modern Motor sports rear 5 lug. I bought a set of 1986 Z31 turbo / 16X7 20mm offset. since the front is push out 3/4 of an inch, on each side due to the z31 hubs I may not need spacers, but I'm debating as far as the rear wheels. has anyone use this wheels? or what offset does a 16X7 needs for the rear wheels. I just want to hear other opinons before making the move of buying spacers. pic od my little project...
