Nissan Multilink Rear Suspension Swap
260DET
I would only buy the rear mounting setup that he offers, the front won't work for us. On the z31, the front mounts are actually wider than the s13, whereas the s130 is narrower. If he sold just the rear studs that he had custom machined I might purchase them. Note that we don't have the same diff mounts either that they use to align the metal plate. Not really a problem though as you can just remove your original mount.
For my setup, I am leaning towards the same solution for the rear. Steel plate with the studs welded in and then weld the plate to the frame member. That seems to be the easiest way to get the subframe straight.
I agree with tec280zx but i'm going to have to try somthing like this because I have already snapped one axle and i'm going to add a lot more power so I'm going to have to do something like this to strengthen the rear end
Yes but there is nothing saying that you have to weld it on at the same angle as the Z31 guys do. I wonder if the front bracket could still be used just facing inwards instead of outwards.
I think at best this is a good refrance and the same affect could be achived using similar methods. (especially for Australians I think this could be "copied" and done cheaper than for us to buy one and have it shiped here)
This is exactly what I was discussing with my engineering friend, who is the same person I'm getting my subframe from. When I get ahold of him again I'll post up the solution he came up with. And due to being easily excitable, I didn't notice that the S13 LCA's were wider until I tried to install them. Do you think it would be a good idea to grab an S13 front crossmember aswell?
Edited by Forcer
If anything I'd get a R31 crossmember and turn it around or something to that effect, also the mounts on SR20's is odd so an S13 crossmember is really not a great thing :<
The good thing to know is that the rear cradle mounts line up with the S130's rear Xmember, the one the diff mounts on. Having a rear structural member right where it's needed is a big plus for a lot of reasons.
True, there is definitely more than one way to skin a cat. I'll be doing the fronts a bit differently than the group buy linked above.
Yup, it works out pretty good. You pretty much have to mount it right where the rear frame piece is in order to get the wheel centered.
For the plate that will house the new rear studs, what thickness do you guys think I should use? I have some 3/8 x 3 inch wide steel that I have lying around that I was thinking of using, but it seems like it might be too thick (and heavy). Never welded on the Z's chassis before and it seems pretty thin. Maybe more along the lines of 1/4 or so?
Also, I plan to get some solid aluminum bushings for the rear and have the machine shop bore it out for the 7/8th bolts to slide into.
R31 pieces are hard to come by here, and I have no intention of putting an SR20 in my Z. It's getting a V-8. More on topic, has anyone considered a Z33 rear subframe?
Fabrication/welding section may be the best place to go for good structural mod advice but to get a reasonable ride height the rear mounts should be up against the Xmember and not spaced down. Remember too that the angle of the suspension subframe front to back affects anti squat, generally speaking the lower the front/the higher the back the less anti squat effect. When doing this job its a good idea to be aware of the effect different alignments will have, it's not simply a 'how can I fit this' job.
Yes the alignment of the subframe will definitely affect things, I suppose it will be a lot of dialing in once I mount it. I plan to have the sub frame right up against the body of the car, its just a matter of getting things out of the way. Another issue now is the hard brake lines, specifically where the hard lines slit off to either side of the car. That piece needs to be relocated in order to get the front up another half inch.
Definately. Here is some good reading from an R/C car manufacture but it directly relates to 1:1 scale cars.
http://www.teamxray.com/teamxray/showfile.php?file_id=6143
and a good reference to how much each item affects handling (eg what to change first for the largest effect).
http://www.teamxray.com/teamxray/showfile.php?file_id=2531
The R/C cars are extremely adjustable but if you are doing custom stuff things like the sub frame orientation roll centers will affect anti squat and anti dive, etc....
Wow, I didn't know those little RC cars were so involved! I never had ones that cool when I was a kid.
