Fuzzydicerule Posted January 20, 2012 Share Posted January 20, 2012 Im thinking about using TTT's AE86 Adjustable LCA Kit when i do mine. It consists of their Block, Standard thread insert, and Reverse thread Heim joint (on the car adjustability) and are weld it. I used this kit to make some adjustable LCA's for my buddies 73 Celica Lift back and it worked phenominally, and the width of the LCA's on that seems similar to the ones on the Z. The only thing that needed modification was the Boxing plate, which needed to be trimmed to the right shape. This Kit http://technotoytuning.com/productdetail.php?p=772 Quote Link to comment Share on other sites More sharing options...
MrKrispy1183 Posted August 16, 2012 Share Posted August 16, 2012 Don't mean to unintentionally bump, but read all the testimony so far. Does anyone have any experience with the Futo Fab setup? It has me curious, as I'd be running an LCA setup in conjunction with Mack/McKinney's coilover setup Quote Link to comment Share on other sites More sharing options...
Mikelly Posted August 17, 2012 Share Posted August 17, 2012 The biggest problem I had and have with the adjustable lower control arms available was the fact that you had to remove the bolt to adjust the arm. Mine always have had the ability to be on car adjustable. The key to a good arm is the BEST quality heim joint. Try to buy them without the heim joint and source your own. I have contemplated getting back into the game on these. My arms are on over 100 cars up front with zero returns. Mike Quote Link to comment Share on other sites More sharing options...
MrKrispy1183 Posted August 17, 2012 Share Posted August 17, 2012 I totally agree with the ability to be on-car adjustable, which something lacking with, what seems like, all current available options. Mike, if you do get back into making yours, I would most definitely be on board. Quote Link to comment Share on other sites More sharing options...
mark Posted August 17, 2012 Share Posted August 17, 2012 The Ttt front control arms are adjustable on the car Quote Link to comment Share on other sites More sharing options...
