boosting issues
New 2 z
my Z wont go past 11psi almost like a safe guard. I removed the pop off valve and capped it so thats not it. I have a internal wastegate with a boost controller. the turbo is upgraded it is not original.
when i floor it from a stop it hit 15 psi, sometimes 20psi and then drops to 11 psi. anyone have any ideas?
Edited by New 2 z
  On 6/2/2011 at 10:29 PM, NewZed said:
You have a boost control problem but did not say much about your boost controller.
Some information on the "turbo upgrade" might also help.
it's the Stock nissan garret T3 turbine section and a upgraded .60 trim Garrett T04E compressor wheel/housing. the engine has seen 15+ psi before so I doubt it's a gasket somewhere.
boost controller was a DIY built spring and ball. i max it out ALL the way where the spring is forced onto the ball and nothing.
  • 3 months later...
