Tony D Posted December 16, 2011 Share Posted December 16, 2011 Or you could have fittings for the manifold cut 1/8 NPT on one end with a 10 or 14 mm o-ring end on the other like the back side of an o-ring injector and then your manifold log fits just like it dies on top of injectors... That short enough? Quote Link to comment Share on other sites More sharing options...
josh817 Posted December 16, 2011 Share Posted December 16, 2011 Clippard Pneumatics. Derek on here referred me to them. I never went through with my project but they have press fit hoses. You know the type where you press down the sleeve on the fitting, stick the hose in, and when you try to pull the hose out it locks it. First I saw them was when I use to play paintball... and you're pressurizing the system to 250psi on that so I think they will hold. The hose is a tiny thin hose, it could fit inside 5/8" fuel line; 6 of them (still don't understand why you want 6?) would tie wrap nicely. http://www.clippard.com/fittings/ They're called "puch-quick fittings" They come inline, elbows, T's, whatever. Quote Link to comment Share on other sites More sharing options...
madkaw Posted December 16, 2011 Author Share Posted December 16, 2011 Tony, not quite visualizing your idea, but I don't have much experience with injectors either. Josh, thanks for the idea with quick- push connectors.'I see a problem when trying to remove the log and six fittings at the same time, don't have enough fingers for that. I want six lines to increase vacuum signal for the brake booster and to act as a balance tune for the triples. Quote Link to comment Share on other sites More sharing options...
TimZ Posted December 17, 2011 Share Posted December 17, 2011 Not sure if i like TimZ 's idea of strapping to the side of the valve cover. FWIW, It's not "strapped" to anything - it uses an aluminum bracket that bolts to two threaded mounting holes on the top of the valve cover, which makes for easy removal and replacement. Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 17, 2011 Share Posted December 17, 2011 I tried posting photos of what I mean but it was excruciating when the iPhone apparently crashed when posting it. No time to do it again! Quote Link to comment Share on other sites More sharing options...
madkaw Posted December 17, 2011 Author Share Posted December 17, 2011 Didn't mean to sound critical there Tim. The angle on the picture made it look like it is laying against the valve cover. Your idea still might work for me now that I have taken a closer look. I either need to set it right on top of the manifold to clear my linkage on the triples or further up and away like yours. Anyone want to enlighten me on the size and thread of the bungs on this Mikuni manifold??? I assumed they were 1/8 npt, but they seem smaller then that. I measured the thread pitch and it comes close to .80mm thread. I want to get some barbed fittings on order. FWIW, It's not "strapped" to anything - it uses an aluminum bracket that bolts to two threaded mounting holes on the top of the valve cover, which makes for easy removal and replacement. Quote Link to comment Share on other sites More sharing options...
madkaw Posted April 4, 2012 Author Share Posted April 4, 2012 (edited) A quick question reagarding the vacuum log. Anyone see any issues with hooking up a PCV on one end of the vacuum log while hooking up my MC booster on the other end? Edited April 4, 2012 by madkaw Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 5, 2012 Share Posted April 5, 2012 I believe I used 1/8NPT on mine, but I may have retapped them...it was a while ago. Like 1991. Quote Link to comment Share on other sites More sharing options...
madkaw Posted April 5, 2012 Author Share Posted April 5, 2012 ???? I believe I used 1/8NPT on mine, but I may have retapped them...it was a while ago. Like 1991. Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 5, 2012 Share Posted April 5, 2012 IOW: 1/8 BSP or one of the 1/8 NPT... but forgive me, I don't recall which, I put my log on in 1991, and don't remember if I ran a tap down it. I doubt I did since the stick plugs were probably easily matched at a place with the barbed fittings. I have taps this size laying around, I don't see it as a major workstep to run a tap through them (even to clean out sealant residue) so insignificant is the effort involved it has slipped from my mind over the past 21 years. There, does THAT explain my response to the question "do anybody know the thread size of the ports"? It seems more polite than "what does it matter, you're running a tap down them for cleanup anyway, use the right tap the three sizes possible are so close it will be what you need by the time you finish." Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 5, 2012 Share Posted April 5, 2012 As for PCV/brake booster I think that was answered on page one... But it's bee my setup since my original vacuum tubing array in 1985... Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 5, 2012 Share Posted April 5, 2012 iPhone keypad sux Quote Link to comment Share on other sites More sharing options...
