tryangle Posted August 30, 2011 Share Posted August 30, 2011 (edited) Hey guys my names Devaughn and after many 4AG builds a reliable motor for the car was needed and I decided on the VQ. Around Jan I pulled my old motor and sold everything in favor of the VQ and all parts needed for the swap. The build went without a hitch and really fits great, only issuse is now it wont start. The harness is from an 03'350z,its modded by Zfever for universal install and its been sent back twice for reinspection. The motor is from a 03'G35, 6speed trans with a F1 racing flywheel and clutch. Problem Im having right now is getting no spark, it has started and fumbbled around once but would not run well. The coils on the intake side of the motor get hot if you leave the ignition in the on position after 10mins. Im stumped need some insight, and the only code its seems to throw is P0118, replaced the sensor and it stil reads the same. Thanks for racking your brains for me ahead of time. Edited August 31, 2011 by tryangle Quote Link to comment Share on other sites More sharing options...
djz Posted August 31, 2011 Share Posted August 31, 2011 My mate had a problem kind of similar when he didn't have good enough grounds between the block/heads and chassis. He had the battery mounted in the boot in his car, which didn't help. Cool swap, car looks awesome. Quote Link to comment Share on other sites More sharing options...
tryangle Posted August 31, 2011 Author Share Posted August 31, 2011 My mate had a problem kind of similar when he didn't have good enough grounds between the block/heads and chassis. He had the battery mounted in the boot in his car, which didn't help. Cool swap, car looks awesome. yeah my battery is mounted in the trunk and ive run 5 extra ground straps. Two off the battery and one of the trans. one off the block and one off the intake. Plus the ecu is going straight too the negative battery terminal. Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted August 31, 2011 Share Posted August 31, 2011 Well since you're on a modded harness it's pretty hard to tell what's what. The fact that the coils are getting hot is telling me something isn't hooked up right, likely grounding out the coils. Did ZFever label everything for you properly? Most of the plugs only plug in one spot. Are you using any of the other Nissan harnesses? Where'd you get your ECU? I assume Zfever's harness mod deleted NATS and the BCU right? Quote Link to comment Share on other sites More sharing options...
tryangle Posted September 1, 2011 Author Share Posted September 1, 2011 going to run a few more test today and see whats might be wrong. Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted September 14, 2011 Share Posted September 14, 2011 What did you find out? If those Coils are getting hot, then it seems they've got constant power to them. which it should not have. I would be looking for a short. I'm not certain which wires would control that. Have you tried a different ECU? Phar Quote Link to comment Share on other sites More sharing options...
tryangle Posted September 17, 2011 Author Share Posted September 17, 2011 yeah ive tried a 2 other ecus from zfever and nothing has started the motor just yet, coils are still getting hot. Im going to go through it again with a wiring diagram and see if there is something i can fix or at least to make it work. Quote Link to comment Share on other sites More sharing options...
tryangle Posted September 21, 2011 Author Share Posted September 21, 2011 installed new sensors i found cheap just to see, and nothing still. Quote Link to comment Share on other sites More sharing options...
tryangle Posted September 25, 2011 Author Share Posted September 25, 2011 going to install a new flywheel and see if it wasnt picking up right. Quote Link to comment Share on other sites More sharing options...
NewZed Posted September 25, 2011 Share Posted September 25, 2011 I would focus on the circuit from the negative side of the coils. For some reason it's grounded when it shouldn't be. Even if your sensor was stuck in the "trigger" position, modern ECUs and/or ignition modules won't keep the circuit grounded. It sounds like you have a short or the coil negatives' connected directly to ground. Quote Link to comment Share on other sites More sharing options...
voltron209 Posted September 27, 2011 Share Posted September 27, 2011 Make sure you dont have "Constant" and "Ignition" switched up Quote Link to comment Share on other sites More sharing options...
tryangle Posted October 6, 2011 Author Share Posted October 6, 2011 (edited) Make sure you dont have "Constant" and "Ignition" switched up I got it running but its only running on the right bank side(3cylinders), its getting spark so it must not be getting any fuel. What would cause 3injectors not to fire? Edited October 6, 2011 by tryangle Quote Link to comment Share on other sites More sharing options...
tryangle Posted October 6, 2011 Author Share Posted October 6, 2011 (edited) I also sent a message to Zfever to see if there is an issue he has seen like this before. Edited October 6, 2011 by tryangle Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted October 6, 2011 Share Posted October 6, 2011 Everyone replying is giving you some excellent feedback, but your replies are very broad and are lacking detail. Have you tried anything that the experienced members have recommended? If yes or no, please respond in detail so we can better analyze and help you with your problem. Quote Link to comment Share on other sites More sharing options...
tryangle Posted October 6, 2011 Author Share Posted October 6, 2011 Does anyone have a view of the injector wires on the rail? Quote Link to comment Share on other sites More sharing options...
tryangle Posted October 8, 2011 Author Share Posted October 8, 2011 I had two bad coils, replaced hose coils and it runs way better but still wont hold an idle. Im going to try out a new MAF sensor tomorrow, ECU is only throwing one code P1212 ABS/TCS Communication Line, since their is no ABS/TCS can that effect the way it runs? Quote Link to comment Share on other sites More sharing options...
tryangle Posted October 8, 2011 Author Share Posted October 8, 2011 She runs! its sooo fast, had vaccum leaks and the injector harness was run wrong. Started up and runs good power is awesome,cant wait to get her on the street more tomorrow. Quote Link to comment Share on other sites More sharing options...
turbonat240 Posted October 20, 2011 Share Posted October 20, 2011 cool! would be nice if you could share a small video....it sure must be fast! Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted October 25, 2011 Share Posted October 25, 2011 Good Job, Glad you got it figured. Now what caused the issue? It'd be good to see if you could figure out what killed those coils, because, as you know they're not cheap. I'm glad those guys gave you some good support. So how about a Vid? Quote Link to comment Share on other sites More sharing options...
