RB26powered74zcar Posted September 19, 2011 Share Posted September 19, 2011 Wanted to Buy - R200 4:11 long nose. Please PM me if you have one you will let go of.... thanks! Quote Link to comment Share on other sites More sharing options...
rayaapp2 Posted September 19, 2011 Share Posted September 19, 2011 Wanted to Buy - R200 4:11 long nose. Please PM me if you have one you will let go of.... thanks! Wrecking yard down the street from me has a 88 200sx. I checked and it has the R200 in it. Its either a 3.90 or 4.11. The guy at the counter was asking $200 for it. I walked away. There was also a VG30/auto 200sx sitting out at PNP down the way. Im pretty sure thats also a 4.11. Id be willing to help you out with this if your interested. I can at least get you the wrecking yard phone number for the non-pnp. Let me know if I can help. Ray Quote Link to comment Share on other sites More sharing options...
Bob_H Posted September 19, 2011 Share Posted September 19, 2011 I'll check when I get home - I have I think a 4.44 R200 long nose and I think a 3.7 or a 4.11 - not sure? One has a LSD - I think the 4.44. Not exactly what your looking for - but if you are interested, let me know and I'll check the actual ratio to be sure. -Bob Quote Link to comment Share on other sites More sharing options...
Bob_H Posted September 20, 2011 Share Posted September 20, 2011 Sent the PM - but here it is again, I checked and it was a 4.375 R200 long nose with a LSD,(might be nismo, nothing to prove it though), and a 3.7 open. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted September 20, 2011 Author Share Posted September 20, 2011 Wrecking yard down the street from me has a 88 200sx. I checked and it has the R200 in it. Its either a 3.90 or 4.11. The guy at the counter was asking $200 for it. I walked away. There was also a VG30/auto 200sx sitting out at PNP down the way. Im pretty sure thats also a 4.11. Id be willing to help you out with this if your interested. I can at least get you the wrecking yard phone number for the non-pnp. Let me know if I can help. Ray Thanks for the info Ray. I really only want the 4:11 for a diff gear ratio though. I'm looking to match up my trans gears (rb25det) to the diff gear it came with as a new car (4:11). I have a 89 GT-R short nose with a 4:11 & CLSD carrier, that I was planning to put that carrier into a long nose 4:11 open R200 (if I can locate one). If not, it's back to orig. plan. That is to put the 4:11 short nose GT-R clsd in my Z. Doing it that way makes me have to get a longer drive shaft, a pinion flange to fit the drive shaft, and then use the MM 6 bolt billet companion flanges, sub axles, and R230 6 bolt 1/2 shaft kit with custom mossier axle center bars that I already own. I need to buy a short nose diff brace from TTT or MM still.... Long story huh....? Quote Link to comment Share on other sites More sharing options...
