Picked up an early 260Z
I picked up the TWM from Ebay when I bought the triple 45s as a package deal. I went with it because it was new and it is the same Rebello uses on their engines.
I need to get work done, winter is getting in the way!
Gotcha, I've been keeping my eye out for one. I'm not a fan of Cannon's as their throttle rod supports are almost always not aligned, causing throttle return problems. The TWM has beefy cast-in supports that I assume are line-bored straight, plus they don't have a redundant support which can cause binding.
Of course the issue can be fixed on the Cannon by removing the redundant (middle) support and using a stiffer throttle rod...
  • 7 months later...
Brian I am not running a dizzy and running edis plus using the COP setup which really cleans up the bay. Later down the line I will look into hiding the coil harness to clean it up even more.
Thanks for the comments guys!
