voltron_boi Posted November 14, 2011 Share Posted November 14, 2011 Over the weekend I decide to mount up my front and rear calipers onto my 260z. The front are the Toyota 4x4, and the rear are the 79-80 280zx.  First attempt was to bleed the front and it locks while stepping on the brake pedal. Then I move on to the rear and I notice it has been lock. I have a proportion valve that is also install in the brake lines for the rear. Do I need to adjust the valve, or am I missing something? Quote Link to comment Share on other sites More sharing options...
30 ounce Posted November 14, 2011 Share Posted November 14, 2011 Which master are you using? I think the rear drums have a valve in the master cylinder that keeps pressure in the line. See the sticky on the Wilwood master cylinder. Quote Link to comment Share on other sites More sharing options...
ritrebor Posted November 14, 2011 Share Posted November 14, 2011 Not sure if it is the same as a 280z but there is a valve that comes off the master cylinder that is for the idiot light that might be triggered. This valve is between the master and the valve that separates the front from the back brakes. If so you just need to recenter the piston in the valve. ritrebor Quote Link to comment Share on other sites More sharing options...
Miles Posted November 14, 2011 Share Posted November 14, 2011 Just a hunch. The only time I have seen all four wheels drag or lock up is when the piston in the master cylinder does not return all the way to its' resting position. This will keep the return ports covered such that pressure in the lines builds each time you pump the brakes. Eventually the brakes will drag and/or lock up. This is usually caused by an improperly adjusted master cylinder-booster push rod. To relieve the pressure take a 10mm wrench and open the bleeders on the MC. If pressure has built up you will see fluid squirt out and your wheels will now spin freely. Quote Link to comment Share on other sites More sharing options...
voltron_boi Posted November 14, 2011 Author Share Posted November 14, 2011 Ill try out the below after work n see how it goes. This is what I got. 7/8, dont no if it's a regular or a 280zx. Quote Link to comment Share on other sites More sharing options...
