Confirm Stroker
forchunet
  On 11/22/2011 at 12:04 AM, PalmettoZ said:
Your correct, you would need to at least pull the oil pan off to confirm if it is a V07 crankshaft. Also measure the bore diameter, 89mm will give you 3.1L with the stroker crank. Your can't see it from the outside of the motor-
Take the spark plug out and fill the cylinder with fluid at BDC untill it is about to flow out the plug hole. then multiply the volume used by 6 after subtracting ~20 ml for gasket and partial CC volume.
Then agian... *I* wouldn't do that... :blink:
The car ended up being a stroker. Talked to Tony D about it and he remembered the car as being a rebello motor. It's actually the same exact car as the one in this video
. In the end I didn't buy it though and have instead decided to build my own... Edited by forchunet
