Request for photo of driveshaft bolts
BLOZ UP
I lost the driveshaft bolts; the ones I thought I had left as them don't fit quite right. They are threaded only so far and the non-threaded part gets stuck on the companion flange. They are M10s, the correct thread size, and 12mm heads, and they look about the right length...
But I wonder if I'll ever get them off if I tighten them down.
So if someone could post a quick photo of them I'd be happy. Or a link to a picture or whatever. I've looked at google images and ebay, but I can't find anything definitive.
EDIT: No, these are definitely not the DS bolts. I just tightened one a bit and it started to bind. Guess I'll go to the hardware store and pick up some proper ones.
Edited by BLOZ UP
Ah, ok, M8X1.25. That's what I meant to type in the first place.
The non-threaded part is like 8.1mm, which is why it binds. Not sure what those bolts are from, could be Z31 stuff.
Ok, so just some regular old M8x1.25 stuff. I usually put the lock washers under the nut, as per the diagrams.
