ZT-R Posted December 27, 2011 Share Posted December 27, 2011 Hey guys I am looking at AZC front big brake kit. If i upgraded them to 6piston and the cross drilled and slotted 13" rotors will that be to much braking power for a street car? The car only sees the track probably 1 or 2 times a year and weighs about 2550. will have 17x9.5 wheels up front. I don't want something that is gonna be twitchy as all hell. Quote Link to comment Share on other sites More sharing options...
rags Posted December 27, 2011 Share Posted December 27, 2011 They will be very sensitive. Very sensitive. Quote Link to comment Share on other sites More sharing options...
pat1 Posted December 27, 2011 Share Posted December 27, 2011 I have the AZC 4 piston wilwoods 12.2 inch rotors on all 4 corners and those brakes are awesome. I think that the 6 piston would be a overkill for the street, Infact the wilwoods I have is a overkill for the street. Quote Link to comment Share on other sites More sharing options...
johnc Posted December 27, 2011 Share Posted December 27, 2011 You don't need brakes designed to stop a 3,200 Viper running the 24 hour of Daytona on a street driven 2,500 lb. Datsun. Balance is more important then mass in good braking and with those 6 piston caliper and 13" front rotors your brakes will be so front biased a well maintained stock braking system will work a lot better. Quote Link to comment Share on other sites More sharing options...
Pete Sprenger Posted December 28, 2011 Share Posted December 28, 2011 The AZC big brake kit will *NOT* make your brakes twitch! One reason racers go to bigger brakes is for better/easier modulation without lock up. Tether reason is obviously for thelarger heat sink. However, if you only do the front, your alliance will be off, even if you install an adjustable biase valve. 13" brakes are certainly over-kill for the street (I personally love overkill, my entire car has been designed around the concept) , and only you can decided the upgrade is worth it for the two times a year you go to the track. Quote Link to comment Share on other sites More sharing options...
zero Posted December 28, 2011 Share Posted December 28, 2011 Along the same lines, I'm going to be buying brakes pretty soon. I was wondering if the Silvermine 11.8" (cobra?) rear kit would be a reasonable match for the 12", 4 piston AZC Wilwoods up front. I'd like to retain a parking brake without installing a second caliper in the rear. Quote Link to comment Share on other sites More sharing options...
zack_280 Posted December 28, 2011 Share Posted December 28, 2011 I have the 6 piston fronts/4 piston rear set from AZC with the wide version 12.2" front rotor and 12.2" rear. Mine are very easy to modulate, but I need to install a proportioning valve since the rears are locking up before the fronts. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted December 28, 2011 Author Share Posted December 28, 2011 Currently I am running z32 rear brakes. I would like to upgrade them later but for now i think they are ok. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted December 28, 2011 Author Share Posted December 28, 2011 Does anyone have pics of the 13" drilled and slotted rotors AZC sells? Quote Link to comment Share on other sites More sharing options...
rags Posted December 28, 2011 Share Posted December 28, 2011 Here is mine with as it stands with the 350Z wheels mounted. Joe Quote Link to comment Share on other sites More sharing options...
ZT-R Posted December 28, 2011 Author Share Posted December 28, 2011 Tasty, any closer ones? Quote Link to comment Share on other sites More sharing options...
