Where to buy Tokico BZ3099
  On 2/4/2012 at 8:29 PM, SUNNY Z said:
The only ones i was finding were complete sets with perches on them. Maybe i'm not searching the right thing? :blink:
The eBay sellers put up a generic Tokico shock picture. Its not a picture of the actual unit you're buying.
  • 3 weeks later...
so I took your advice and ordered them off ebay......19 days ago
They're back ordered, and they won't know how long out until after march 1. FML
Anywhere ELSE to get them?
Or are there other available comparable options?
Edited by SUNNY Z
Wait, I hope I'm not stating the obvious... But you do know that the 3099's require sectioning, right? Usually, people use them in the front and the (3015 if i remember correctly- the front s30 shocks) in the rear, giving roughly a 1.5" section for each side. This is what I've chosen to do. I'm probably telling you something you already know, but just thought I'd make sure you knew...
They don't require sectioning. You can put a spacer under the shock and run it in stock length strut tubes.
Well yes, you are correct. But then what's the point of using the 3099's versus just using the actual 240z fronts, the 3015's? And then what's the point of having coilovers anyways, since you don't want to lower much more than just lowering springs would go without sectioning.
OK now i'm super confused. When I spoke with you a while ago John, I told you that i was doing a ground control coilover kit, and planned on sectioning the struts. So are you saying that these won't be appropriate for my application, because i'm planning on lowering the car ~2+"?
Anyway, I guess i have four of them now........ :huh:
Most people run a longer rear strut than front strut (not sure why but they do), although I'm sure the 3099 will work, it may be important to get a longer insert (the 3015). I'd definitely recommend sectioning... seeing as how you want to lower the car. Read the FAQ on it, and take your time. It should work out fine.
