SUNNY Z Posted April 16, 2012 Author Share Posted April 16, 2012 That picture is deceiving. The tire actually tucks under the flare, and can turn full lock to lock without touching. It will need to come up some. I mounted the top of the flare 3.75" above the center of the spindle. The camber in those pictures is about stock. I just installed camber plates, so that's where the camber is from. Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted April 16, 2012 Share Posted April 16, 2012 On 4/16/2012 at 3:32 AM, SUNNY Z said: It will need to come up some. I mounted the top of the flare 3.75" above the center of the spindle. Wouldnt the center of the spindle need to be at least half the tire diameter from the top of the flare...like about 13 inches or so? And the spindle moves up and down in relation to the flare so is that measurement at ride height, compressed or full droop? It looks like you have the jack under the control arm in the pic...if you raise it by itself doesn't that compress the suspension more than static ride height before the car begins to lift off the jackstands? Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted April 16, 2012 Author Share Posted April 16, 2012 On 4/16/2012 at 5:55 AM, Bigdeezs said: Wouldnt the center of the spindle need to be at least half the tire diameter from the top of the flare...like about 13 inches or so? And the spindle moves up and down in relation to the flare so is that measurement at ride height, compressed or full droop? It looks like you have the jack under the control arm in the pic...if you raise it by itself doesn't that compress the suspension more than static ride height before the car begins to lift off the jackstands? Excuse me, the 3.75" measurement was from the bottom of the fender (center front to back), and of course it tapered out from there.I actually cut 2.75-3" Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted April 16, 2012 Share Posted April 16, 2012 ahh...thank you for the clarification Quote Link to comment Share on other sites More sharing options...
v8dats Posted April 18, 2012 Share Posted April 18, 2012 good info. Looking forward to ordering my wheels. So from what I gather the 9.5 wheel will fit with a 275 tire and zg? Anyone road test? Thanks Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 18, 2012 Share Posted April 18, 2012 Yes I've driven mine, albeit not hard yet. It fits under nicely for me. Dave Quote Link to comment Share on other sites More sharing options...
v8dats Posted April 18, 2012 Share Posted April 18, 2012 (edited) What I meant to say was.. Hows the fitment with the 17x9.5 rbr on the front of the z with a 275 40 tire. Thanks. Edited April 18, 2012 by v8dats Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 18, 2012 Share Posted April 18, 2012 Can you rephrase the question, I am unclear what you mean. Dave Quote Link to comment Share on other sites More sharing options...
v8dats Posted April 18, 2012 Share Posted April 18, 2012 Edited. Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted April 19, 2012 Share Posted April 19, 2012 heres his car with the 275-40-17s judge for yourself... Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 19, 2012 Share Posted April 19, 2012 Thanks bigdeez! For clarity, that top pic is with extra castor wound on, and before any trimming. The pic under it is drivable with castor returned to stock, and about an inch taken out of the front air dam (both the side, and the top flange section where it bolts to the body). Dave Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 19, 2012 Share Posted April 19, 2012 (edited) Phone images from the front. The drivers side needed a lot more trimming than the passengers. Also note the huge crease in the first pic where I didnt' trim enough then took it for a drive. Whoopsy. Dave Edited April 19, 2012 by thehelix112 Quote Link to comment Share on other sites More sharing options...
v8dats Posted April 19, 2012 Share Posted April 19, 2012 (edited) Awesome. Thanks guys. Beautiful cars Edited April 19, 2012 by v8dats Quote Link to comment Share on other sites More sharing options...
Turbo6.0 Posted May 27, 2012 Share Posted May 27, 2012 Just ordered my gun metal RBR's from RacingLab (17 x 9.5 all around). I plan on getting 275/40/17's as well. Anyone else besides thehelix112 & sunny z running this setup? What tires do you guys recommend for a street car? Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted May 27, 2012 Share Posted May 27, 2012 I am...275/40/27 Nitto NT01s..I just got back from running it on Mulholland a few hours ago...just wow is all I can say I just went out andc snapped a few... Quote Link to comment Share on other sites More sharing options...
Turbo6.0 Posted May 29, 2012 Share Posted May 29, 2012 On 5/27/2012 at 11:36 PM, Bigdeezs said: I am...275/40/27 Nitto NT01s..I just got back from running it on Mulholland a few hours ago...just wow is all I can say Thanks for the response. Car looks soooo sick! Where did you get your flares from? Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted May 29, 2012 Share Posted May 29, 2012 thanks! MSA... http://www.thezstore.com/page/TZS/PROD/50-1562 Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted May 29, 2012 Share Posted May 29, 2012 What suspension are you running bigdeezs? Also I'm pretty sure those aren't street tires, . Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted May 29, 2012 Share Posted May 29, 2012 the P030-0032 bilsteins on stock valving with shortened strut tubes, coil overs sleeves, 10" eibach coils 250#F 275#R and camber plates/shock tops made from these... http://www.ebay.com/itm/MK1-Universal-Fit-Adjustable-Camber-Plates-Nissan-Datsun-240Z-260Z-280Z-200SX-/140759525954?hash=item20c5ebea42&vxp=mtr the car is noticeably under sprung with these tires through the corners...just madness Quote Link to comment Share on other sites More sharing options...
turbeau Posted May 29, 2012 Share Posted May 29, 2012 By under sprung do you mean the springs rate should be higher? Are you talking street or race conditions? How much spring travel do you have? Thanks Quote Link to comment Share on other sites More sharing options...
