wickiewicked240z Posted March 3, 2012 Share Posted March 3, 2012 I have a summit racing plastic fuel cell with the 0 ohm 90 ohm sending unit the tube type. Well the float sinks makes the gauge read incorrectly is there away to coat the float with a coating so it won't sink. Or should I just switch it with arm style sending unit? Quote Link to comment Share on other sites More sharing options...
Zero83 Posted September 12, 2013 Share Posted September 12, 2013 Does it fill with gas? Quote Link to comment Share on other sites More sharing options...
z240 Posted September 12, 2013 Share Posted September 12, 2013 If its hollow, it must have a hole/split and is filling with gas. If its new, send it back for a replacement. If not, use a gank tank sealer to seal the hole/crack. POR makes a sealer. Don't use anything that will add much weight. Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 12, 2013 Share Posted September 12, 2013 How about ordering a new float? Anything that adds weight will cause the reading it skew. And I'm not to hot on using a hair dryer on a plastic float to dry out the interior before coating it with something that may or may not fix it! How much can it be to get a new float? Quote Link to comment Share on other sites More sharing options...
