Zero83
Everything posted by Zero83
  1. give this a read, http://www.zcar.com/forum/10-70-83-tech-discussion-forum/81389-what-problem-my-gearbox-280zx-5-speed.html
  2. hm, idk man, let me do some looking around.
  3. Fiberglass resin and abs plastics work very well together, just use a mat fiber backing and it will literally be stronger in the repaired location than in original condition. I also like to use the mat fiberglass as apposed a roll because for some reason it just lays out flatter and wont curl on you. sand and paint with any combination of rattle can paint or rubberized bed liner is awesome, just test it on something else first for how much stippling it has after its dry. different brands, different end result.
  4. I put them directly behind my seats... Not in the lids to the tool boxes but in the wall of the tool boxes. Works great.
  5. There are mounting brackets in my 240... run new wiring!! It will save alot of trouble. I used an after market Sony into a equalizer slash pre-amp out to my front and rear speakers And it also has a designated line out for the sub im currently installing.
  6. Installed new pertronix and new coil. Car ran fine on points prior to install. Won't start after installation. Nor will it start after i pulled the pertronix and put points back in. Im thinking the coil is bad even though its new and im getting some spark from it. Anyone done this install before? Need help plz!!!
  7. Yeah it is blue
  8. Yes and no. Its probably a blown fuse but possible that its a loose ground. Go through. Your fuse box check all fuses. And clean all contact Points with contact Cleaner. If that dosent help start checking for loose or damaged wires. Also inspect your blinkers while your at it they could possibly be shorting out.
  9. Ok guys thanks im going to swap out for an electric Fuel pump and hope for the best.
  10. Dual webber su carb with cannons not sure of size. I ment to look them up just haven't yet.
  11. Okay i can't seam to find where i read about oil dilution. The datsun service manual states to check oil for fuel but it doesn't say what to do if fuel is present. I read somewhere that the s30's have an common issue which causes fuel to get into the oil but at that time i didnt have the problem so i payed no attn. Oops. Can any one help? The head is an e88 and the block is from a 280 and now my oil smells like gas bad.
