Are bumpstops required with coilovers?
They are not required. You're better off relocating the inner LCA mount in the crossmember if you want to reduce steering kickback.
He said bumpstops, as in when the suspension bottoms out. Are you sure you're not thinking of bump"steer"?
Nigel
If in doubt, put it together and go test drive it. The thing I love about my coilovers is that it is pretty easy to work on them. You can always go back and put bump stops on if you need them. Depending on your springs, and how much you sectioned your struts, you may coil bind before you bottom between the gland nut and the top insulator/spring seat. The next question to torture yourself with is "how large of a bumpstop should I use?" I had a set of tokicos that came with bumpstops that slid tightly over the strut rod. I cut them in half and run 1/2 on the front and 1/2 on the back because they were so tall.
