Help - I can't get inner CV off shaft
RebekahsZ
Doing the JMortensen axle swap / CV rebuild.
#1 how the heck do I get that stinkin' inner CV off the shaft??? I have been whacking it with a brass drift until I'm afraid I'm gonna snap a tooth off of the big star fruit-shaped thing-em-a-bob in the center of the CV. The "sticky" references using a pipe - can anybody describe that technique in detail? Or tell me where he heck I'm supposed to whack this thing to get it to come off! Maybe I'm just not whacking it hard enough - should I worry about breaking things?
#2 take a look at the photos I've added. Does the wear on this first outer CV look acceptable? Should I rotate the star-fruit thing-em-a-bob 180 degrees to get eliminate the wear pattern that the balls ride on?
I only ripped off 2 fingernails getting the old boots off and the new boots on the new shafts - that is pretty good for me.
I have a goal of getting to the strip with R200 CLSD with slicks on May 17th.
Keith
You'd have to be the hulk to damage the gear. I haven't taken one apart, but it shouldn't be that hard. I might try hitting it on once or twice to jar it loose. Perhaps the circlip is in a crazy bind.
If you get a pipe a little larger than the shaft, you can put slide the pipe over the shaft, lock it down, and yank on the shaft itself to pop the end off. An even force on the gear should make it come off easier than hitting it off center.
In your pic 1 have the shaft in the vice vertically with the inner cv pointing down. Use a dead blow hammer and strike the gear as close to the shaft as possible while holding the inner cv in your other hand to support it as it comes off.
Edited by 24OZ
This might help: http://forums.hybridz.org/index.php/topic/105657-300-zx-turbo-cv-shaft-disassembly-and-reassembly/page__p__988589__hl__%2Bcv+%2Bdisassembly__fromsearch__1?do=findComment&comment=988589
How do the balls look? If they aren't pitted you're probably OK. It's tough to tell if that is pitting or just spots on the last pic of the inner race. Does it feel smooth when you articulate the joint?
My balls are great, wait- you mean the car - for a minute I thought this was a dating site. The balls look fine. The joints felt smooth until I took them out of their wear pattern.
I appreciate the help. That video makes it look so easy! I've been beating the hell out of it. Gonna buy the exact dead blow hammer one of you showed and I'll try not to worry about breaking parts- I'm in the same spot either way I guess. For the pipe method, do you worry about the pipe diameter and what part of the joint it rests on?
I had no luck using a dead blow hammer but the pipe method worked perfect. I used 1-1/4 galvanized pipe and slammed it against a block of wood to prevent damaging the shaft when it let loose from the joint.
Edited by rossman
I couldn't go to sleep without giving it one more try with the info you guys have given me. Mounted axle in vise with inner stub hanging down. Grabbed the stub with left hand and pulled down while whacking (the CV) with a soft rubber dead blow hammer (my old one). I was not careful or timid. Came right off in a few smacks. I think two things were key: positioning the axle so that I could put a constant pull against the snap ring, and not being afraid of breaking anything. You guys gave me the confidence to be as rough as I needed to be. I didn't worry about breaking anything because of the video and your reassurances. Went ahead and did second axle - the whole dissassembly took me like 20 minutes (now that I know what I'm doing)! Thanks so much for this forum and all who contribute. Now to go to the JMortensen thread on dissassembling the inner CV! And, I can return the new $16 dead blow hammer!
