4 bolt su carb oil q's
I just got my su carbs on my 260 today and wanna know what kind of oil I need to put into them and how much, one of them is low on oil and needs to be topped off. I know it's noob question but carbs are alien technology to me lol.
Regards.
Edited by battlesquaddatsun
I use 10W30. I am not sure the amount in volume required but there are marks on the damper that you remove to add the oil. It is easy to overfill so add oil with an eyedropper or similar method that is easy to control. I dip a long, thin screwdriver blade into the oil bottle and then move it quickly to the opening in the carb, letting it drip off into the carb.
Sweetness, so basically it's just trivial, as long as it lubes, could probably run KY in them hahaha. Thanks for the help guys.
Not trivial at all. The damping fluid controls the rise of the piston during acceleration (don't go there!). Higher viscosity oil will enrich the mixture during transient acceleration conditions and lower viscosity will lean it out. It also has the potential to get eaten by the engine if you pour in too much so make sure that it's something compatible with a combustion chamber.
