has anyone built a 3.6L L 6
  • 3 weeks later...
I have mocked up a block with a crank in it, but it was only 88mm stroke. (half of a broken diesel crank, turned the journals to fit L24e small-journal rods.) Piston choices became very limited, unless you wanted to use the wet-sleeved diesel block.
  On 7/18/2012 at 10:17 AM, PMC raceengines said:
Well its a go we built it with a 89mm bore and 96 stroke , on the dyno soon with custom water systom like FIA head , you tube vid soon ..
Can't wait to see the youtube Peter. Good luck on the dyno.
Hi mate
we can run it both ways , but so far we have run it normal and had some great resolts 170f at full lode 5min and all the EGT all the same and AFRS could be run very lean , full power runs in the 13s for 5min with bp6 plugs and 370hp on pump fuel over 300lbs and 11.1 comp , its a good thing .
  • 1 month later...
